lankyri Posted September 21, 2005 Report Share Posted September 21, 2005 me and flower were talkin about joining a two mavic D521's together running two inner tubes but 1 massive tyre would it work my question is or would the tubes just explode after a drop from the two inner walls i no fatmikes got a picture of them joined but does it work hope you can answer this question cheers ric :D Quote Link to comment Share on other sites More sharing options...
will4eva7k Posted September 22, 2005 Report Share Posted September 22, 2005 (edited) now, how are you going to get a strong wheel build? 16 - 18 spokes per wheel ...err good idea but i dont think its going to last or stand the forces i meant, its not going to work i would just save the hassle buy a fat rim u will have a stronger wheel its cheaper and it will last longer Edited September 22, 2005 by will4eva7k Quote Link to comment Share on other sites More sharing options...
flower Posted September 22, 2005 Report Share Posted September 22, 2005 fat rims are mad of cheese thats why i wanted to get to 521's (as there the best ) and weld them together, with a little tinkering it should work. But we have looked at all the last details yet. Quote Link to comment Share on other sites More sharing options...
Simon Posted September 22, 2005 Report Share Posted September 22, 2005 Both "Ali C" and "Fatmike" have done it, PM them and they should gladly help you. As far as i know, there rims are holding up fine. Quote Link to comment Share on other sites More sharing options...
flower Posted September 22, 2005 Report Share Posted September 22, 2005 thankyou simon Quote Link to comment Share on other sites More sharing options...
Todge Posted September 22, 2005 Report Share Posted September 22, 2005 Im running a Mavic D321 on the rear. Super strong, wide enough, and theres just enough room to fit a brake pad on :D Quote Link to comment Share on other sites More sharing options...
flower Posted September 22, 2005 Report Share Posted September 22, 2005 how heavy is it? Quote Link to comment Share on other sites More sharing options...
ian Posted September 22, 2005 Report Share Posted September 22, 2005 yeah isnt fatmike running his tubeless? you can do it by welding them together and getting rid of the middle sidewall where you welded them together so you can just run one big tube and a big tyre Quote Link to comment Share on other sites More sharing options...
flower Posted September 22, 2005 Report Share Posted September 22, 2005 its more the rim lacing and how to get rid of the side wall. I dont want to start grinding it down for example then it will splitt. so im await infomation on how to build. Quote Link to comment Share on other sites More sharing options...
ian Posted September 22, 2005 Report Share Posted September 22, 2005 lace it as you would a normal wheel. if you join the rims to the spoke holes are next to each other than it hould all be good. just get longer spokes and all should be good. Quote Link to comment Share on other sites More sharing options...
flower Posted September 22, 2005 Report Share Posted September 22, 2005 fair doos Quote Link to comment Share on other sites More sharing options...
JIX Posted September 22, 2005 Report Share Posted September 22, 2005 Dont weld them together though because I think ali said the heat made the metal reall soft and so it was no better for grinds than a try all rim. But I think Phil (select bikes) said there was a method of hardening the metal again which was pretty simple. Try a search on the topics because there was loads of info in them :D Quote Link to comment Share on other sites More sharing options...
batesie Posted September 22, 2005 Report Share Posted September 22, 2005 any photos of this ?? Quote Link to comment Share on other sites More sharing options...
Simpson Posted September 22, 2005 Report Share Posted September 22, 2005 OOOooo! like the thinking but you forgot the most usefull point, if you got 1 puncture you COULD still ride lol :D Quote Link to comment Share on other sites More sharing options...
Gavin Posted September 22, 2005 Report Share Posted September 22, 2005 i'm pretty sure u could harden the metal again by heating it up untill its glowing then dipping it in cold water, but i wouldnt like to mess about with it myself. have you considered one of those massive sun rims? their huge, rather strong, and they come in a lime green colour! cant remember the name of them though. i'll edit tis post when i find out :sleeping: Quote Link to comment Share on other sites More sharing options...
aaron_trials _247 Posted September 24, 2005 Report Share Posted September 24, 2005 (edited) Dont weld them together though because I think ali said the heat made the metal reall soft and so it was no better for grinds than a try all rim. But I think Phil (select bikes) said there was a method of hardening the metal again which was pretty simple. Try a search on the topics because there was loads of info in them :) heat treating :S DAN an and rick if you do need any tiggin done gimme a shout Edited September 24, 2005 by aaron_trials _247 Quote Link to comment Share on other sites More sharing options...
lankyri Posted September 24, 2005 Author Report Share Posted September 24, 2005 not really appart from front brake needs bleeding bout it though, bikes running really smooth for once i love it Quote Link to comment Share on other sites More sharing options...
Ali C Posted September 24, 2005 Report Share Posted September 24, 2005 I did indeed do it. I removed the inner walls and got them welded, Fatmike kept the walls inplace and ran bolts though it, solves all the problems of heat, but is heavier. I dont think its really worth doing, not when the new echo rim is comming out, 48mm wide and supost to be as hard as alex rims, so should hold grinds better than current wide rims. I also used a sun doublewide, they are pretty decent, holds grinds really well, but the angled braking suface can be a pain for setting pads up with, I also flat spotted mine really easily, but it did have big holes in it. Quote Link to comment Share on other sites More sharing options...
lankyri Posted September 24, 2005 Author Report Share Posted September 24, 2005 sounds good ali but flower wont want a grind hes a proper street prankster lol but thanks for everyone helping out :) Quote Link to comment Share on other sites More sharing options...
Danno Posted September 24, 2005 Report Share Posted September 24, 2005 Fatmike did it with a Mavic 717 and 719 and originally bolted it together with 8 3 or 4mm bolts, however this didn´t work too well as the rims tried to pull apart from each other under the stress of riding. Therefore he used another 8 bolts, so a total of 16 bolts and it seems to work fine at the moment. It is fairly straight forward to do, but does take a while. It is something different though and you do get the main benefit of amazing brakes due to a decent grind because of the material being alot harder then echo/koxx/onza rims etc. However it is heavy, but I think Mike plans on going tubeless to save weight as he has to use a DH tube to avoid getting flats easily. Hope this helps, Dan. Quote Link to comment Share on other sites More sharing options...
Dan-Walker Posted September 24, 2005 Report Share Posted September 24, 2005 Arnt the d521 rims 27 mm wide, it is going to be f***ing wide 54 mm and pretty heavy to the rims i think are about 600 grams each so will be a heavy, 1200 grams. Quote Link to comment Share on other sites More sharing options...
