PaRtZ Posted September 21, 2005 Report Share Posted September 21, 2005 OK thanks to Tartybikes I now have a zona zip frame (yay!) So i started putting it altogether put my Gigapipe BB in, and at the time of posting, I am 3 turns away from screwing the right hand side in. Only problem is its Compleltly stiff and will not budge Have I got the wrong sized bb? Im using the spacer on it (and its still 3 turns after the spacer) Confused :unsure:. please helppp Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted September 21, 2005 Report Share Posted September 21, 2005 cleanage, and lubeage me thinks, probarbly a bit of grit on the threads of the bb or something? Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted September 21, 2005 Author Report Share Posted September 21, 2005 Its weird though cos i can take it out so easily, but then it gets stiff really quick when i start to put it back in :unsure: I just realised how dodgy that sounds.... Quote Link to comment Share on other sites More sharing options...
Danny Posted September 21, 2005 Report Share Posted September 21, 2005 Is the bb shell threaded all the way through? Or is there an unthreaded section in the middle? Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted September 21, 2005 Author Report Share Posted September 21, 2005 (edited) nope there is an unthreaded section in the middle. The cups haven't gone into about 10mm of the innermost thread (on the right hand side) so there is still plenty of thread left for them Edited September 21, 2005 by PaRtZ Quote Link to comment Share on other sites More sharing options...
JT! Posted September 21, 2005 Report Share Posted September 21, 2005 (edited) Welcome to the wonderful world of bb's that don't fit into Onza frames. :unsure: This is what you have to do: You have to file the section in between the red lines as this bit gets stuck and will not go past the unthredded bit. You have to take quite a bit off, but it only took me 10 mins when i did it. Take a bit off and keep trying it to see if it fits, and take it slow when you putting it in the frame. It does work as i did it 2 days ago. (N) Edited September 21, 2005 by JT! Quote Link to comment Share on other sites More sharing options...
Burton Posted September 21, 2005 Report Share Posted September 21, 2005 when i had my T-lite, i had to grind the bearing lip off my Truvativ dh bb. Try that? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted September 21, 2005 Report Share Posted September 21, 2005 left side in half way, drive side in all the way then the left all the way. The left hand side guides the rh side in :unsure: Quote Link to comment Share on other sites More sharing options...
BikeDotStuffAtOnzaDotCom Posted September 21, 2005 Report Share Posted September 21, 2005 left side in half way, drive side in all the way then the left all the way. The left hand side guides the rh side in :unsure: Agreed - that's the way to get an ordinary Truvativ ISIS BB into a T-Lite. You have to take both cups off first, sometimes. That's for BB shells like the T-Lite that have thread for the BB, then a "step" up to an unthreaded bit before stepping down to the thread on the other side. The sealed bearing unit can't get over that centre section while it's still in one of the cups. I have to admit at this point I haven't looked into the BB shell of a Zip. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted September 21, 2005 Author Report Share Posted September 21, 2005 Ok I appreciate these great answers thanks Unfortunatly I turned into caveman botch mode and used mole grips :"> Its in though :unsure: wooo Ill get some pics tommorrow when its lighter (N) Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted September 21, 2005 Report Share Posted September 21, 2005 wahey :D Quote Link to comment Share on other sites More sharing options...
JT! Posted September 21, 2005 Report Share Posted September 21, 2005 Agreed - that's the way to get an ordinary Truvativ ISIS BB into a T-Lite. You have to take both cups off first, sometimes. That's for BB shells like the T-Lite that have thread for the BB, then a "step" up to an unthreaded bit before stepping down to the thread on the other side. The sealed bearing unit can't get over that centre section while it's still in one of the cups. That or just file it off, more fun and destructive. ;) Unfortunatly I turned into caveman botch mode and used mole grips :"> Its in though :P wooo Ill get some pics tommorrow when its lighter :D :D Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 21, 2005 Report Share Posted September 21, 2005 Just to put my 2 cents in - my Gigapipe's gone in perfectly. It's creaking like hell, but it went in fine apart from Truvativ's shit BB tool interface, and the fact the interface part of the BB is made of clay. Quote Link to comment Share on other sites More sharing options...
