emery Posted September 20, 2005 Report Share Posted September 20, 2005 I'm struggling to remove some grips as there proper crap and is there any lube or anything you can use to get them off . toby (Y) Quote Link to comment Share on other sites More sharing options...
Mc Lovin Posted September 20, 2005 Report Share Posted September 20, 2005 I'm struggling to remove some grips as there proper crap and is there any lube or anything you can use to get them off . toby (Y) get a flathead screwdriver and run it around the bar. and lever them off, or if u dont want the grips cut them off, :)" tom :) Quote Link to comment Share on other sites More sharing options...
basher Posted September 20, 2005 Report Share Posted September 20, 2005 i think hair spray works or it might be deodrant not sure it rubs off easy and doesn't make the grips spin around. Quote Link to comment Share on other sites More sharing options...
llandudno_trialsboy Posted September 20, 2005 Report Share Posted September 20, 2005 if you dont want the grips cut them off or what i used was wd40 with a flatheaded screwdriver Quote Link to comment Share on other sites More sharing options...
Urpedigreechumdog Posted September 20, 2005 Report Share Posted September 20, 2005 Quote Link to comment Share on other sites More sharing options...
mad dan Posted September 20, 2005 Report Share Posted September 20, 2005 when i remove grips or put them on i use compressed air. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 20, 2005 Report Share Posted September 20, 2005 Ha wish I'd seen this topic like 20mins ago, I've just split my foam grips in two!!! haha. I've got some old ones on now though. ash Quote Link to comment Share on other sites More sharing options...
am4zin Posted September 20, 2005 Report Share Posted September 20, 2005 compressed air is probably the best way of getting grips on and off the bars, but i dont have an airline, so for me the best way is useing hairspray. using a small flat head screwdriver, try and force a gap between the bars and grips, then spray hairspray into the grips. this worked for me taking the grips off, but i couldnt use the hairspray trick to fix the grips onto my new bars, so i took it to my bike shop and they used their airline to put the grips on (Y) Quote Link to comment Share on other sites More sharing options...
Simpson Posted September 20, 2005 Report Share Posted September 20, 2005 Spray deodrant under the grips using a flat head screwdriver, once re-inserted the deodrant will evaporate away an lock on solid, sorted! Quote Link to comment Share on other sites More sharing options...
aff1e Posted September 20, 2005 Report Share Posted September 20, 2005 cut them off :) Quote Link to comment Share on other sites More sharing options...
emery Posted September 20, 2005 Author Report Share Posted September 20, 2005 Yer mate I've just done them so thanks for the help ,used deodrant toby :) Quote Link to comment Share on other sites More sharing options...
