Advantages / Disadvantages Of 8mm Bolts For King Rear Hubs
Ingram
I have some on my bike which is never used but would definately reccomend them
Good
- Arguably a firmer hold/less liekly to let the wheel slip
- Less likely to get damaged/bent/fooked
- Stiffer rear end
- Stronger
- Looks cleaner
- Probably lighter
Bad
- You have to have the 8mm allen Key on you to take your wheel off
- You need to pay extra for them and require the HD axel as well.
I love mine, I snapped 2 normal axles then got the heavy duty ones, not had a problem yet.
There are a couple of disadvantages though:
I have to completley unbolt my rear mech every time I take my wheel out as the bolt heads wont clear it.
I had to modify my control to actually get the rear wheel in.
needs an 8mm allen key to get wheel out
