bullitt Posted September 19, 2005 Report Share Posted September 19, 2005 Everyone is talking about rim grinding and I feel like a complete retard because i dont know what it is :">. PLease help me. Quote Link to comment Share on other sites More sharing options...
Dai the Socket Posted September 19, 2005 Report Share Posted September 19, 2005 Angle grinder with Grinding or Cutting disk on. Wack your wheel from your frame, go around with it spinning at an angle, leaving a slight indentation. Loads of lines and grooves. Pads grip to them = improved braking in wet and generally a better brake. :) Quote Link to comment Share on other sites More sharing options...
philking Posted September 19, 2005 Report Share Posted September 19, 2005 Angle grinder with Grinding or Cutting disk on. Wack your wheel from your frame, go around with it spinning at an angle, leaving a slight indentation. Loads of lines and grooves. Pads grip to them = improved braking in wet and generally a better brake. :) And if you want that in english, it translates to be.... Run around the side wall of your rim with an angle grinder. This will roughen the side wall causing there to be more friction with the brake pads, in turn giving better braking. Quote Link to comment Share on other sites More sharing options...
Siders77 Posted September 19, 2005 Report Share Posted September 19, 2005 (edited) When you're done it should look like this. :) Edited September 19, 2005 by Siders77 Quote Link to comment Share on other sites More sharing options...
philking Posted September 19, 2005 Report Share Posted September 19, 2005 Nice i was just looking for a pic like that, but you beat me to it! :) Quote Link to comment Share on other sites More sharing options...
ollie Posted September 19, 2005 Report Share Posted September 19, 2005 hey thanks you saved me from putting apost in the "random question bit" because i have never seen a ground rim before thanks! (p.s i did know what one is) thanks ollie Quote Link to comment Share on other sites More sharing options...
Zoo_Monkey Posted September 19, 2005 Report Share Posted September 19, 2005 just afew quick extras there are different types of grind - light and heavy some pads work better with light grinds some better with heavy, equaly some suck with a light grind and some wear down so quick with a heavy grind they only las 1-2 rides, the pic of the rim above is a heavy grind also before you butcher your rim you need to consider grind direction ie, the lines "drawn" buy the cutting/grinding disk should apose the braking action - check the pic (Y) best to get someone who has some experience to do it for you the first time hope that helps Quote Link to comment Share on other sites More sharing options...
MrMonkey Posted September 19, 2005 Report Share Posted September 19, 2005 Rim Grinding can mean different things depending on what cirlces you socialise in. (Y) Quote Link to comment Share on other sites More sharing options...
Si-man Posted September 19, 2005 Report Share Posted September 19, 2005 Rim Grinding can mean different things depending on what cirlces you socialise in. (Y) LMAO!!! I must be on the same wave length as you then Quote Link to comment Share on other sites More sharing options...
Zoo_Monkey Posted September 19, 2005 Report Share Posted September 19, 2005 LOL - dont ask me to draw any instructional pics of that! Quote Link to comment Share on other sites More sharing options...
Alun Goch Posted September 20, 2005 Report Share Posted September 20, 2005 hey check out the pic in the link below (ul have to scroll down a bit) its a rim thats been slashed loadsa times. anyone know how to do this? it looks to tidy to be done by hand! http://vtcz.ch/index_3.php? Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 20, 2005 Report Share Posted September 20, 2005 Couldn't see what you were talking about on that page? (Y) If you right click on the picture of wherever the rim is, just go Right Click - Properties - then copy the http://www.vtcz.ch/whateveritscalled.jpg part which will come up, and put that in here :) Quote Link to comment Share on other sites More sharing options...
Alun Goch Posted September 20, 2005 Report Share Posted September 20, 2005 http://vtcz.ch/bilder_tech/felge_raendel.jpg cheers Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 20, 2005 Report Share Posted September 20, 2005 A-ha, yeah. What he's done in knurled the rim surface. Similar to the above. You can machine the knurling onto it, if you or someone you know is good enough. I don't really know how long they last, although that looks fairly deep/well done, so it might last longer than a grind. Bet it *eats* pads though... Quote Link to comment Share on other sites More sharing options...
Siders77 Posted September 20, 2005 Report Share Posted September 20, 2005 I thought Onza were going to do it but didn't because when it was tested it ate pads up too fast? Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 20, 2005 Report Share Posted September 20, 2005 Nah. They machined circles into the rim (so it was like a grind, only more consistent), but the brake only held one way (Y)\ Quote Link to comment Share on other sites More sharing options...
Siders77 Posted September 20, 2005 Report Share Posted September 20, 2005 Ah right, that's what I must have been thinking of then. That's the one. (Y) Quote Link to comment Share on other sites More sharing options...
