the_soon_to_be Posted September 19, 2005 Report Share Posted September 19, 2005 firstly i have done several searches and found nothing, so could someone tell me if you could set the rear magura 4 bolt mount up using a d521 rim, i have heard that the rim is not wide enough ? gaz.... and what is the best forks to use, i have been thinking about pashleys, would they ride any good ? Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted September 19, 2005 Report Share Posted September 19, 2005 The rear brake spacing is 100mm if I'm correct. My toxsin has 100mm and there is just enough room for my ronnie. Actually, now that you've said this, I wouldn't risk it personally. I think you'll find the revell will ride rather similar to the base. Keep the base till it snaps and then worry about new frames :) Quote Link to comment Share on other sites More sharing options...
the_soon_to_be Posted September 19, 2005 Author Report Share Posted September 19, 2005 yer maybe, just pimp out rest of parts then when it goes snap, then purchase new frame, sam your on the ball gaz... Quote Link to comment Share on other sites More sharing options...
