Grips
joshonza
get lock-ons :'( never have them moving again ;) but if you cant afford, dont want lock-ons then use hair spray, it goes on wet making the grip easier to go on and when it dries its solid like glue ;) that should sort out your problem mate
p.s dont forget to leave them for a while to dry :D
Get some wcs foam grips, put the end on, then put the end of a handheld bike pump over the other end, make sure the opposite end of the bars is sealed, then pump the grip on, (might need two people to do this). no lubricants involved so grips go on as tightly as possibly, iv had no trouble with mine, they are locked on solid :) , hope this helped
Edited by flipkickbs
i have tried the following
- grips + hairspray, touch and go you need to have realy clean bars and grips or they take ages to set
- zip-grips/ zip ties and grips, same as above the zip-ties yous stop the ends moving
- celulose paint (cheap halfords car paint) + any grips works grate use hairspray to desolve the celulose to get the grips back off.
- lock on grips, perfect but if you bash them around alot you end up having to cut them off altho they are the best solution over all
trust (Y)
yeh at my bike shop they use compressed air to slide the grips on without putting anything between the bars and grips. when i got new bars and a stem, i went to the bike shop and got them to put the grips on tight for me cos the hairspray trick didnt work for me (Y)
