Pedal Problems
emery
You culd probably get it tapped out (re thredded) by your local garage. But someone will confirm that.
I find if you try putting it in applying pressure in different directions, sometimes they go in right. But it's trial and error in what direction you have to push it.
Edited by JT!
yeah thats what i would do but just be carefull. you dont want to be buying somenew cranks :'(
yeah thats what i would do but just be carefull. you dont want to be buying somenew cranks :D
Ok i'm planning on getting some new cranks but would the pedal be ok
Well, just look at the threds, then see which is damaged. Most likely be the cranks, and chances are the pedal threds will be fine.
