Chris King Hub Wobble
nb88
www.chrisking.com
but in your axle ou sholad have a 5mm allen key shaped hole at either end, tighten these...is the simple way, but the website will have more info
this is more than you need, but the very end f it should show you what to do nicely
here bbbbbooooyyyyy
Edited by ben@hulltrials
Leave the wheel in, just take out the qr. Loosen put 2 allen keys into the end of the axel. They are imperial size but a normal allen key should be alright. Loosen these using the allen keys. Then with your hand tighten the cone on the non-drive side as tight as you can with your fingers, then do the axel back up tight and it should be fine.
