What Size Bb For A Koxx Lb?
matheprat
Linky Looks like its 118 ;)  (Y)  :angry:
Yeah that's why I bought the BB I did. However, the non-drive side plastic cup thingy seems to screw all the way into the frame, so the lip on it is flush with the BB shell on the frame, and it comes loose from time to time, even though the threads in the frame are fine. The cranks themselves also sit right up at the end of the taper, and all I can see looking down is the little semi-circular bit at the end of the taper. Basically the cranks are as far up the taper as possible, and so im not sure if they are on it properly or not...?
Cheers
