Kool 710, 810, Khe Collapse
Mr Motivator
At the mo I'm using a KMC Kool K710 (1/8, the fat one). I'm using this with a 16t Ti 'Burn bash, and it's worn down the bash so it fits fine now.
I'm considering getting a KMC Kool K810 (the thin one) as it's lighter, narrower and just as strong. It will have more clearance too on the bash.
I've also heard good things about the KHE Collapse, but I've heard that it's wider than a fat kool, which isn't good.
So, bearing in mind I want to spend no more that a tenner.. I'm thinking of getting a narrow kool, or I might have to just get a fat one cause they seem more available.
So can anyone shed any light on this about the widths etc, and usage with a Ti bash.
Samm
although you dont wonna spend more than a tenner ide STRONGLY recomend getting the KHE collapse as imo kools are dog meat as when you land on them the links fray and bend whereas with the KHE there ment to be grinded on ect ect and the tensile strength is much greater. :-
tiz youre choice buddy
but when one of the most important and use components on a bike goes wrong :- , as in your chain, the consequences are devastating so always opt for the strongest possible. espeically if you go big (N)
Hi, I'm 'didlers' as spacemonkey put it earlier.
The collapse fitted my ti-bash perfectly, it was jumping off of my 14 tooth sprocket at the back. I think this is because the the spacers beside my sprocket were too big and didn't let the chain sit properly on the teeth. If you're running a 15t sprocket down back then you should be fine.
Anyways I have decided to give my collapse to spacemonkey and I'm sticking with a PHat kool, I hear what DW said about them but I hardly knock the chain anyways and have found them fine, despite one snapping on me a few weeks ago and destroying my knee, but was my fault.
This collapse thing wont work with gears I take it.?
No, well not without serious cut and shut bodges, so lets just say no.
The chain is this beefy:
If your a mod rider basically you should be riding a collapse chain :-
If you ride stock single speed and it doesn't rub or anything get one too (N)
If you run gears stick with a Kool its your best option.
