Sanding A Rim With Sand Paper Or Any Alternatives
Luke_bradley
Grind it, grind it now. Its the onel way. Tar is non prous so water just sits on it, crap in the wet. With a grind, the water sits in the grooves so doesnt rob the bite of your brake so much. It doesnt compromise your rim strength, as long as your sensible and dont grind it every week. Use mavic rims and these last ages with grinds. They arent made of marmite like these buy all products are.
I sand papered my rim once or twice. Depends what kind of sand paper you use. I got the roughest kind. The only good that comes out of it, is that if you're applying tar, tar goes on easier, and not as messy if u were to apply it onto a grind.
Agreed though. Grinds are where it's at.
f**k the stanley knife, f**k the sand paper.
Make love to the angle grinder.
F***ing is the same as making love to, you div!
What you meant to say was stick the knife and paper up your arse and treat the angle grinder like you would a lady friend. ( Be gentle and the results speak for themselves, an all out sexually frenzy)
GRIND ALL THE WAY
