emery Posted September 12, 2005 Report Share Posted September 12, 2005 Whats the way when you like ride up to a wall and lift on your front then lift up your back roll on your front then give it a big pull to land back on your back wall. This would be helpful for me to learn, therefore improve my riding also how do you get the big pull back to work. toby Quote Link to comment Share on other sites More sharing options...
picki Posted September 12, 2005 Report Share Posted September 12, 2005 is either a front hook or a front touch? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted September 12, 2005 Report Share Posted September 12, 2005 I call them a moving wheelswap. Theyre great for when your in tight situations, I can get about 40" from about 6" away. It just takes a lot of practice Quote Link to comment Share on other sites More sharing options...
Simpson Posted September 12, 2005 Report Share Posted September 12, 2005 Its just front wheeling then using the modualtion of your brake to perform a rolling endo lifting your back up thats all Quote Link to comment Share on other sites More sharing options...
emery Posted September 12, 2005 Author Report Share Posted September 12, 2005 (Y) I can do that bit but its when you get back onto your back whhel without the front wheel touching . toby Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 12, 2005 Report Share Posted September 12, 2005 Do you mean a rolling transfer? If so It Is basically a transfer/wheel swap but just start rolling. Roll at the wall, start small, lift the front wheel at the last second and just touch your wheel on top of the wall and then preload for about a second and just spring. This needs to be performed In one swift motion and Is a very complex move to learn for a beginner and takes ALOT of practise. ash. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted September 12, 2005 Report Share Posted September 12, 2005 start with them on curbs, trhen work your way up, you should not need to use your brake, just surge up the wall. (Y) Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted September 13, 2005 Report Share Posted September 13, 2005 I think he means an 'up to front wheel'. Roll towards the wall and when your about 6 foot away, do a wheeile hop and land with your back wheel still on the floor and your front wheel about 6-12 inches away from the wall, this is a good way to preload for this move. Then give a powerfull kick to pop the front wheel up and over the ledge, keep your front break locked, and bring your back up, pushing the front wheel down. To keep it up on the front wheel your going to need to lean towards the bar with your front brake still locked and then quickly transfer your weight forwards and release the front brake, wheelswaping your bike to the backwheel. It's quite hard at first because you'll be automatically wanting to go to backwheel. Quote Link to comment Share on other sites More sharing options...
bousfield19 Posted September 15, 2005 Report Share Posted September 15, 2005 have a look in some back issues of mbuk ashton and akrig did a how to on this a couple of months back i will add the exact issue when i get home tonight jamie Quote Link to comment Share on other sites More sharing options...
N.Wood Posted September 15, 2005 Report Share Posted September 15, 2005 This what you're after? Those were the days when i could ride :) Quote Link to comment Share on other sites More sharing options...
