Bb Problems
JT!
Yey another problem. :P
Got a new bb, 73 x 128mm FSA DH. Put it in, the left hand side cup only screwed in half way, but i have seen a few riders who haven't got theirs screwed in very far to a ignored it. Went to put the driveside crank arm on and when i got it tightish the freewheels notches were already pressed against the bb shell. :D
I used to run a 124mm bb and the notches had at least 3mm away.
Is it just the way the bb is, or am i missing something?
Whats your old bb? If you thread it into the frame on the rh side you can give it a few taps and the bb will come away from the cup
I though my old bb out, it was in 4 or 5 different peices, cups and all. Still i shouldn't have to do that really.
If you use a 73mm bb in a 68mm frame then you should use a 2.5mm or 5mm bb spacer on the driveside. It won't solve the freewheel rubbing problem, but that way the left hand cup will either screw in all the way(when using a 5mm spacer) or 2.5mm of the cup will stick out in case you use a 2.5mm spacer.
Yeah, that isn't the problem. I don't mind the left had side cup sticking out a bit it's the freewheel rubbing that's the problem.
Shit <_<\
I can't remember how much clearance I had with my FSA... I know with my Gigapipe I've got approx. FA with Tensiles + an Eno, but I want to put my Echo bash on, so I was gonna get an FSA. Hell, I need a new BB anyway so it's not so bad, but still, I'm not 100% sure my bash'll fit w/Eno, as I need another 4mm clearance from somewhere :unsure:
I'm not 100% sure my bash'll fit w/Eno, as I need another 4mm clearance from somewhere :ermm:
Good luck with that :unsure:
I hate all this incompatibility. <_<
Edited by JT!
Erm, second hand, with the 175mm Tensiles you'd have bought from Travistrials like 6 months ago? :">
I honestly don't know, to be honest. Are they out of stock with CRC or something? Tried bikedock?
Either that, or go to Truvativ's site and check their UK distros?
73, not least 'cos the T-Lite's 73mil, ain't it?
Either way, more options for selling it on/putting it in a new frame?
KK, all sorted then. Probably tell me they haven't got them in stock but i'll have a go at them when they do.
Ta duck. <_< :unsure:
If you mean the extractor tabs on the Eno, no.
In that that freewheel costs £83.99 new or something like that (dunno, I got mine somewhere cheap <_<), I'd rather not make it so to take it off I have to remove the driveshell and f**k the body of it up.
Also, I'd save just under 1mm of material (the tabs are only 1mm long, with a 16mm wide body as opposed to the ACS's 2mm tabs/15mm body, so there's not much saving anyway), which isn't really the 4mm I need...
If you were talking about slimming down the BB though, I may have to do that a bit :unsure:\
