tom tom Posted September 11, 2005 Report Share Posted September 11, 2005 (edited) i might be looking for new pads soon, what should i look for if i want to run a grinded mavic 721 with no tar and hold brill with a nicely set up maggie? cheers tom tom :P Edited September 11, 2005 by tom tom Quote Link to comment Share on other sites More sharing options...
Luke Drewery Posted September 11, 2005 Report Share Posted September 11, 2005 There are endless pad topics on here, have a search. :P Plazmatics seem to be very popular for ground rims. I am running the heatsink blues at the moment and they are very good. I only have to use a slight bit of tar every few days, i am talking a tiny amount and they bite and lock very well. Before that i had kox browns and they were the same, slow wear rate, good bite and amazing lock. :D Quote Link to comment Share on other sites More sharing options...
emery Posted September 11, 2005 Report Share Posted September 11, 2005 Koxx bloxx or plazmetic . toby Quote Link to comment Share on other sites More sharing options...
JT! Posted September 11, 2005 Report Share Posted September 11, 2005 Koxx bloxx or plazmetic . toby ← From what i heard: I second that. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 11, 2005 Report Share Posted September 11, 2005 Plazmatic pads are the way forward (CRM's are the ones to get), grind or non-grind. Here is a link to a pad review topic from the sticky in the members section, linky. Should answer your question. ash. Quote Link to comment Share on other sites More sharing options...
bigpimpndave Posted September 11, 2005 Report Share Posted September 11, 2005 (edited) Heatsinks are good on a grind :P :D :( :( Edited September 11, 2005 by bigpimpndave Quote Link to comment Share on other sites More sharing options...
Deonn h Posted September 11, 2005 Report Share Posted September 11, 2005 (edited) Get plazmatic they are awsem with a grind.The best pads i`ve ever used.Just give them a slight bit of tar with the grind and there amazing.They give real bite :P .here scroll down abit. Cheers Deonn Edited September 11, 2005 by Deonn h Quote Link to comment Share on other sites More sharing options...
basher Posted September 11, 2005 Report Share Posted September 11, 2005 plazmatics Quote Link to comment Share on other sites More sharing options...
trialridertom Posted September 11, 2005 Report Share Posted September 11, 2005 heatsinks plazamatics or koxx blocks red are all very good i have had all three and are superb :P :D :( Quote Link to comment Share on other sites More sharing options...
echo_olie123 Posted September 11, 2005 Report Share Posted September 11, 2005 Go for plaz or if you have a proper death metal grind like me get Koxx Bloxx browns because mine work lovley. :P Olie Quote Link to comment Share on other sites More sharing options...
mat hudson Posted September 11, 2005 Report Share Posted September 11, 2005 get either, heatsinks, plaz or koxx Quote Link to comment Share on other sites More sharing options...
spunkey_monkey_boy Posted September 12, 2005 Report Share Posted September 12, 2005 avoid like the plague - rimjams. the reds are great until they peel apart, the blue's are ok until they snap in half and peel apart and the greens are pure shit. heatsink konig's - brilliant pads but expect them to die in about a week, i killed a set right to the plastic in 2 days at fort william, one day competeing and another arsing around. coust pads - expensive but amazing - buy some plaz's - cheaper and still very good - buy there if you cant afford cousts home made's - the way foward if you have the bottle to try it and can't afford new pads all the time... Quote Link to comment Share on other sites More sharing options...
mat hudson Posted September 12, 2005 Report Share Posted September 12, 2005 what you on about, just bung a pencil rubber on your maggie cilinders (Y) Quote Link to comment Share on other sites More sharing options...
picki Posted September 13, 2005 Report Share Posted September 13, 2005 Plazzies - outstanding pads, decent wear rate, super hold and bite. Koxx - never used them, but the brown last for yonks apparantly Heatsink White pads - bit hard, good hold, i didnt have too much bite with mine though Heatsink Honig thingies - at £6 a pair you cannot go worng, enen if they are well soft. Stupid bite and hold, just wear down a bit quick. Kool Stops - Take them off and get some real pads Zoo!'s - Bit of a shoddy wear rate, but good bite / hold and i cant be arsed to go on Quote Link to comment Share on other sites More sharing options...
arran on t-pro Posted September 13, 2005 Report Share Posted September 13, 2005 i run plazmatics with no grind but i use tar so they will be good with a grind probobly.my mate runs cox blox with a grind and they are ace.they lock perfectly and they are reliable :angry: Quote Link to comment Share on other sites More sharing options...
Si-man Posted September 13, 2005 Report Share Posted September 13, 2005 heatsinks plazamatics ← They new or something :angry: (Y) Plazmatics are amazing, get them My koxx bloxx are performing quite well so I shall be sticking to them till they ware Quote Link to comment Share on other sites More sharing options...
Biff... Posted September 13, 2005 Report Share Posted September 13, 2005 Plazmatic pads because i no how amazing everyones brakes work with a grind with them pads. Cheers Kyle. :angry: Quote Link to comment Share on other sites More sharing options...
