T-Unit Tim Posted September 11, 2005 Report Share Posted September 11, 2005 (edited) Hello all. I signed up to this forum a while back, as I was planning on starting trials on my 24Seven V24, well I didn't, and about a month back, I bought a DMR Transition frame, last week I purchased some suspension forks for it after riding for months with rigids, I also put a front brake on for the first time in a year. So.. after a couple of days riding like this, I decided that trials was what I wanted to do. Ive just put some longer bars on the DMR (26" kona DH, to replace 23" EA50s), and had a 20 minute ride in my driveway, and it felt really nice to ride. Now I'm just after a bit of advice of what other parts I should change to make it more trials specific. It's not going to be pure trials, but a lot of trials influence in my riding I think, I will still be riding street, flatbanks & things, just want a nicer feel to the bike. I'm planning on getting a smaller sprocket on the front - 25t & running with my 14t sprocket on the back. Also debating going back to rigids (DMR Trailblades), but any other help & opinions would be great, thanks all. Edited September 11, 2005 by T-Unit Tim Quote Link to comment Share on other sites More sharing options...
zoojames Posted September 11, 2005 Report Share Posted September 11, 2005 I think a longer reach stem would do you some good, around 90mm if you want a bridge, and as your sorting out the gearing it should be ok. What hub are you running on the rear and on what rims? This will make a fair bit of difference as you want a light feeling rear end for ups etc. The transition frame may have some back wheel issues? As its not trials specific geometry I can only imagine that control will be an issue so maybe a more trials specific frame would also be an idea, look at Leesons and Curtis' for info! Hope that helps a bit, James :- Quote Link to comment Share on other sites More sharing options...
T-Unit Tim Posted September 11, 2005 Author Report Share Posted September 11, 2005 (edited) I think a longer reach stem would do you some good, around 90mm if you want a bridge, and as your sorting out the gearing it should be ok. What hub are you running on the rear and on what rims? This will make a fair bit of difference as you want a light feeling rear end for ups etc. The transition frame may have some back wheel issues? As its not trials specific geometry I can only imagine that control will be an issue so maybe a more trials specific frame would also be an idea, look at Leesons and Curtis' for info! Hope that helps a bit, James :- ← Back wheel is an Atomlab GI Dirt (pretty damn heavy), front wheel is an Atomlab Aircorp, (pretty light in comparison). So it's atomlab hubs all-round. Well, I would love to go for a trials frame, but as I bought the DMR only a month ago, and I wont be able to sell it for much, I may aswell keep it for a bit longer, I'll think about those frames though mate, but not for a while. (Wanted the Curtis a while back, but quite pricey) Edited September 11, 2005 by T-Unit Tim Quote Link to comment Share on other sites More sharing options...
Dr. Nick Riviera Posted September 11, 2005 Report Share Posted September 11, 2005 try fitting a rear magura to prevent the tears when the disc tabs snap :- and as james said , a longer stem will help loads Quote Link to comment Share on other sites More sharing options...
T-Unit Tim Posted September 11, 2005 Author Report Share Posted September 11, 2005 Yeah, I was going to ask.. Why do nearly all trials rider use rear rim brakes? Ive run a V-Brake for most of the year, and it was pretty good, but put a Mini back on in the week, and it is so much nicer, just a lot more feeling on stalls & things, and you don't have to worry about trueing wheels. Quote Link to comment Share on other sites More sharing options...
The Dude Posted September 11, 2005 Report Share Posted September 11, 2005 id say buy an ashton ET replica, and whack all the parts on, that would feel awesome with a very hoppy feel, but still able to flow round parks/dirt like a beast. and get a rear magura on, or a decent V, discs are perfect for the front, but just put too much strain on the back. and a smaller chainring + bashring should be a beast then. Quote Link to comment Share on other sites More sharing options...
T-Unit Tim Posted September 11, 2005 Author Report Share Posted September 11, 2005 Update... I've put rigids on the bike now, and a standard Mini rather than Mono, so now I have a really good front brake, bike is feeling really nice, longer stem next. I have a 60mm Kona Clump stem, I guess this would do to be getting along with, untill I can afford something good, like a Hope maybe. This is going to turn out good hopefully, and when I get more money, I will be able to afford new wheels, a Ti axle for cranks & maybe a frame. Quote Link to comment Share on other sites More sharing options...
