Front Brakes
cp101
Magura HS33 - solid, reliable, nice lever feel when you bleed with water.
Plazmatic CRM pads - grippy as hell, nice modulation, work pretty well in the wet too.
Light grind - helps with wet weather riding, and for a bit more lock.
Perfect.
I spent a while trying to adjust avid single digit 3.0 ( 25 bucks, can't go wrong ) can't adjust the springs for shiat, its just annoying as hell.
