How Do I Put A Seat On My Bike?
bquamb
I have a small problem...
I don't know how to get a seat onto my bike :">
It dosent have a latch and it dosent have a place where to seat post can latch on.
Is the a wedge that i could put in the tube so that my seat wont move? or can u just not put a seat on a bike like that?
hey!! my monty seat has a 45 degree system where the end of your seat tube is set to 45 degrees and a little thin on the end is the same and when you tighten the bolt in the seat tube it pulls the little bit up inside and grips to the seat tube. then the actual seat bit bolts to the seat post. (Y) hope you under stand this :">
http://images.google.co.uk/imgres?imgurl=h...3D%26safe%3Doff go to the monty foam seat and seatpost and its that design. (Y)
Edited by sir trial a lot
