emery Posted September 8, 2005 Report Share Posted September 8, 2005 on my t-lite what forks and what else would i need to change to get a disk setup toby and how much in total Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 8, 2005 Report Share Posted September 8, 2005 That post made no sense :) Anyway: Echo Easy Disc Only = approx. £80 Avid brake = £50-ish (call it £55 incl. cable) Avid SD5 lever = £10 Total = £145 or so for that. If you need the hub too, it's gonna be about £38 for a Hope XC front hub, then an additional £15 for spokes 'n' build (maybe as much as £20). So, in total, you're looking at £203 or so. Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted September 8, 2005 Report Share Posted September 8, 2005 That post made no sense :) Anyway: Echo Easy Disc Only = approx. £80 Avid brake = £50-ish (call it £55 incl. cable) Avid SD5 lever = £10 Total = £145 or so for that. If you need the hub too, it's gonna be about £38 for a Hope XC front hub, then an additional £15 for spokes 'n' build (maybe as much as £20). So, in total, you're looking at £203 or so. ← Ouch, thats a hella lot! Glad i already have one :) Is definately worth it though Quote Link to comment Share on other sites More sharing options...
emery Posted September 8, 2005 Author Report Share Posted September 8, 2005 sorry in a rush lol is it worth it is there a cheaper option toby Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted September 8, 2005 Report Share Posted September 8, 2005 sorry in a rush lol is it worth it is there a cheaper option toby ← There may well be a cheaper option, but that one's a quality set up. Is exactly what i'd have if i rode mod. Pete Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 8, 2005 Report Share Posted September 8, 2005 Not really? Disc hubs aren't worth getting cheap crappy versions of 'cos they'll die, wheelbuilding doesn't get cheaper, the Avid disc is £49.99 from CRC atm, that Avid lever's cheap anyway? You could get some cheapo forks, but they'd be heavy and weak? So it's either do it and don't cut corners, do it and cut corners and end up with broken components, or just get a front Magura or something. Quote Link to comment Share on other sites More sharing options...
