Snapped My Bolt
emery
last night i was riding and i done a a gap and pulled my brake then heard a pull the a snap look down and the bolt holding my brake snapped in two can this be replaced and should it happen or was it a mechanical fault or my fault and has this happened to anyone else
toby :P
It happens, there is a hell of a lot of force on such a small bit of metal.
If you can't get the other bit out of the the Frame/Forks then you may have to drill it out. It;s nothing major, if you don't know how find a mate that does or any good bike shop should be able to handle the job.
Good luck.
H
just incase you already haven't replaced it, you could look at buying high tensile bolts if it happens again. i would still have a good look around the brake area to see if there are any defect with the frame (e.g mount angled inwards at the top) which would create unneccessary stresses on the brake / bolt
