Urpedigreechumdog Posted September 6, 2005 Report Share Posted September 6, 2005 Ahoy me ol' shipmates, i have a maggy with slow returning internals. It returns slow whether it is bled or just on it's own. I have taken out the internals and cleaned the inside with a dremel, but no sucess, it still returns slowish. Help please? :P Quote Link to comment Share on other sites More sharing options...
steve sturt Posted September 6, 2005 Report Share Posted September 6, 2005 Please dont think Im being rude here but have you over tighteed the screw that bolts the lever to the body? Its a 5mm allen bolt that acts as a fulcrum. Hope thats all it is, if not then its something more srious. Quote Link to comment Share on other sites More sharing options...
Urpedigreechumdog Posted September 6, 2005 Author Report Share Posted September 6, 2005 No, it's not that, i checked that a few days ago :P Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted September 6, 2005 Report Share Posted September 6, 2005 Did you put oil or thin grease on the piston before putting it in the lever? Have you made sure the slave cylinders are clean? Try replacing the spring in the lever or stretching it a bit. Make sure the lever body isn't distorted or bent. Quote Link to comment Share on other sites More sharing options...
Urpedigreechumdog Posted September 6, 2005 Author Report Share Posted September 6, 2005 Grease may be the answer, i'll give it a try.... Cheers The spring is new and the slaves are clean anyhoo. Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted September 6, 2005 Report Share Posted September 6, 2005 Make sure it's thin grease or lubricating oil (but not WD40!!). It will also help to seal the piston, meaning less chance of leaks. Quote Link to comment Share on other sites More sharing options...
rich4130 Posted September 6, 2005 Report Share Posted September 6, 2005 Is it water bled? Same happened to mine, all gunked up, just needed cleaning. Quote Link to comment Share on other sites More sharing options...
Siders77 Posted September 6, 2005 Report Share Posted September 6, 2005 This happened to mine once. I tryed EVERYTHING and then found that the TPA was on too tight and it sorted it out. :"> Quote Link to comment Share on other sites More sharing options...
Urpedigreechumdog Posted September 6, 2005 Author Report Share Posted September 6, 2005 I used some oil and it hasn't done the job :P Might try some grease at a later date, i'm in the middle of fixing a cracked lever with some epoxy resin atm instead lol. Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted September 6, 2005 Report Share Posted September 6, 2005 if it comes to it....unattach the slaves. Pull out the piston with pliers (sp?) and see how it goes back when unbled. My old maggie (~3 yrs) just seized up...no amount of lubing helped. It was water bled.... adam Quote Link to comment Share on other sites More sharing options...
Urpedigreechumdog Posted September 6, 2005 Author Report Share Posted September 6, 2005 stuck a load of lard round the internals and then put them back in, seems to have half done the job :P Quote Link to comment Share on other sites More sharing options...
