T-pro Geomatry
c.kezer
they can range from anything around the 1005 mark to around the 1030 mark as mine is a 1027 :ermm:
hope this helps >_<
I don't think he specified wheelbase, he said geometry. Why not go and measure some other lengths/angles/heights of your frame for the lad :blink:
Edited by tom!e
My wheelbase works out as around 990-ish mm.
Chainstays are, I think, either 365mm or 372mm... I have a hunch they're 365mm, but I'm not 100% about that at all.
What frame are you comparing it to?
EDIT: Same geometry as the Levelboss 20, and they've (short and long) got 350mm stays, so I'd have thought it would've been the same for the Pro.
