Magura Bleeding
pashley pro
hi im having serious problems with my brake ive tried to bleed it with braided hosing on and the first few pulls of the lever the piston travel quite far out then it just deterrites till they dont come out at all. so i think the hose is leaking. is this a common problem and can i send it back do you think?
I had this problem when i went to braided.
I ended up sealing the hose at the wheel end with plastic glue. Even after it wasn't leaking it was still really sluggish and slow.
Crap basically.
I went back to plastic hose and it's so much better I wouldn't ever dream of trying braided again.
'Cause thats just me, plenty of peeps have managed to use it and still have a good brake.
But if i you asked me for adivce, i would say stick with plastic hosing, and just adapt it so it's a bit mroe resliant to snapping, (like i have).
Isn't it just because the braiding its-self is wank and just expands? hope braided is supposed to be pimp.
you seriously need to learn some dstuff and stop listening to ian all the time
a lot more people than you think use braided hosing and none of it is shit
it is exactly the same hose inside just with a steel braiding (making it stroinger in effect) around it
DAN
Cheap braided hosing = crap mine and 3 friends all leaked/popped in the first few weeks. e.g. Unex (macdonalds straws)
Decent braided hosing = The mutts nutts. e.g. goodridge or hope.
But to be fair it's just not needed unless you twist your bars over 270 degrees on a regular basis, or run short hoses. Stick with the plastic stuff, it works fine.
what is lubricating, i e: not water, yet thinner than maggy blood?
WD FORTYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
or
GT EIGHTYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY FIVEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
Edited by James_Porter
gt85 dont work...its thinner than water and wont go up the srynge properly
was quite funny to try though
might have to have a blast with wd40.
does any one know if you can mix maggy blood and some spray lube and it all hold together? ie not seperate?
