jamiequin Posted September 1, 2005 Report Share Posted September 1, 2005 (edited) i cant find the spec on the internet, me and my mate are having a competition to see who has the lightest bike he has a onza t rapter and the frame weighs about 7lbs (apparently) could any please help find the weight of the base ta26 cheers jamie http://www.trials-forum.co.uk/forum/index....pe=post&id=1993 Edited September 1, 2005 by jamiequin Quote Link to comment Share on other sites More sharing options...
Bucky Posted September 1, 2005 Report Share Posted September 1, 2005 not very heavy. heres an idea ride your bike instead of comparing it to other peoples.>_< Quote Link to comment Share on other sites More sharing options...
jamiequin Posted September 1, 2005 Author Report Share Posted September 1, 2005 not very heavy. heres an idea ride your bike instead of comparing it to other peoples.;) ← >_< you cant say you dont it is natural. (Y) (Y) Quote Link to comment Share on other sites More sharing options...
Bucky Posted September 1, 2005 Report Share Posted September 1, 2005 >_< you cant say you dont it is natural. ;) (Y) ← i ride other peoples bike an see how their setup feels and try get ideas for my riding but i wouldnt go making a topic asking if my own bike is heavy(your the one riding you should know). why not weigh them both and stop being sad and go out riding together. Quote Link to comment Share on other sites More sharing options...
jamiequin Posted September 1, 2005 Author Report Share Posted September 1, 2005 i have not even got the frame yet. Quote Link to comment Share on other sites More sharing options...
Blackghostknife Posted September 1, 2005 Report Share Posted September 1, 2005 Ok enough of the bitching ladies (Y)" the frame weighs 5 lbs with the bash so i'm not sure how much it os without te bash, just minus the weight of a bash from the frame if u wanna go ultra weight-weenie, and t-rexs weigh nothing like 7 lbs >_< Quote Link to comment Share on other sites More sharing options...
Endohopper Posted September 2, 2005 Report Share Posted September 2, 2005 As stated above , the TA26 is plenty light with the bash removed , and lighter still once the now redundant mounting posts are sawed / grinded off . Nice frame in black . Quote Link to comment Share on other sites More sharing options...
jamiequin Posted September 2, 2005 Author Report Share Posted September 2, 2005 As stated above , the TA26 is plenty light with the bash removed , and lighter still once the now redundant mounting posts are sawed / grinded off . Nice frame in black . ← surely the bash guard is not that heavy, i was going to keep it on, shall i.? Quote Link to comment Share on other sites More sharing options...
Krisboats Posted September 2, 2005 Report Share Posted September 2, 2005 theres no point keeping the bash on, just use a bashring on your crank it'll do the job fine. plus the bash that comes with it is a standard crappy metal bashplate and it isn't very strong at all. My first one snapped whenb i was taking it off the frame. all i did was unscrew the bolts :) :)" They don't ride heavy either because of the short chainstays. so they ride like a super paper machine just a bit stronger. Quote Link to comment Share on other sites More sharing options...
jamiequin Posted September 2, 2005 Author Report Share Posted September 2, 2005 (edited) theres no point keeping the bash on, just use a bashring on your crank it'll do the job fine. plus the bash that comes with it is a standard crappy metal bashplate and it isn't very strong at all. My first one snapped whenb i was taking it off the frame. all i did was unscrew the bolts :) :)" They don't ride heavy either because of the short chainstays. so they ride like a super paper machine just a bit stronger. ← can i ask why your sig is a link to this topic with the title my nice red shiney base ta26, :) how easy is it to angle grind down the bash mounts? Edited September 2, 2005 by jamiequin Quote Link to comment Share on other sites More sharing options...
Trebor Posted September 2, 2005 Report Share Posted September 2, 2005 The bash isn't attached to the frame at the mo Jamie. You'll have to put it on delicatly as the mount has been hit a few times (I didn't use it with the bash). It is possible to put it on the frame though - hence the pictures with it on despite the knackered underside bit! T-Raptors are not 7lbs, more like 4lbs. Angle grinding stuff is a piece of piss, just have to watch out for the metal bits flying off in all directions! And be very careful when you get close the bottom bracket/frame tubing around that area. Quote Link to comment Share on other sites More sharing options...
jamiequin Posted September 2, 2005 Author Report Share Posted September 2, 2005 (edited) The bash isn't attached to the frame at the mo Jamie. You'll have to put it on delicatly as the mount has been hit a few times (I didn't use it with the bash). It is possible to put it on the frame though - hence the pictures with it on despite the knackered underside bit! T-Raptors are not 7lbs, more like 4lbs. Angle grinding stuff is a piece of piss, just have to watch out for the metal bits flying off in all directions! And be very careful when you get close the bottom bracket/frame tubing around that area. ← oh ok, i will keep it of a have a bash anyway. thanks for all the replies. :) Edited September 2, 2005 by jamiequin Quote Link to comment Share on other sites More sharing options...
