emery Posted September 1, 2005 Report Share Posted September 1, 2005 when i do this i can do it ok but when theres a drop the other side i get a bit nervous as i feel that i wont land my back wheel on the wall and slip. whats a good way to go about making sure you land your wheel perfectly and this also happens on static gaps then landing on another wall, i fell off because i didn't land the rear wheel properly what helps you target a specific place toby Quote Link to comment Share on other sites More sharing options...
Biff... Posted September 1, 2005 Report Share Posted September 1, 2005 While you keep practicing and improving your confidence will also improve it just take time. >_< Cheers Kyle. Quote Link to comment Share on other sites More sharing options...
jamiequin Posted September 1, 2005 Report Share Posted September 1, 2005 practice!. >_< Quote Link to comment Share on other sites More sharing options...
trialridertom Posted September 1, 2005 Report Share Posted September 1, 2005 When your wheeling up a wall and theres a drop at the other end stick your backside as far back as possiable and it should roll you down as there is no weight on your front end and is less chance your going to go head over tit, hope this helps it helped me alot >_< (Y) Tom.................. Quote Link to comment Share on other sites More sharing options...
