Neighbour Stealing Wireless Internet
butcha87
Hey,
Recently my internet has been really slow and sometimes when I play games online my ping rockets for no reason (I.E. All p2p programs are closed etc.). I checked my router settings (Netgear) and it turns out there is someone elses computer in my attached devices. This is what is stealing my internet. How can I encrypt my router or otherwise prevent the little shits from stealing my bandwidth?
In your router setup program there should be an option to turn on MAC address filtering (Dont turn it on Yet!). Find the MAC address of your machine (not sure where you can find that in Windows) and enter that in the list of machines that can have access to the router, then turn on the filtering. That should stop them!!
I used to do that to the girls i shared a house with when they pissed me off....
Henry
Hey,
knock on their door and kick them in the balls B)
alternatively, if that doesn't work, do it again :P
knock on their door and kick them in the balls :P
alternatively, if that doesn't work, do it again (Y)
^^^ Gets my vote ^^^
Stick a password on you router then they shouldunt be able to connect :P ?
It has to be someone nearby soo Take a large stick and hit who ever it is and tell them they owe you money for stealing you broadband .
If all of the above fail go cable B)
Sam
Edited by samthebiker
MAC filtering is the best way and most secure. Also you can use WEP, but that's not as good and harder to set up I think. So use either MAC filtering or MAC filtering AND WEP, if you like. All the settings should be on your router - It should give you a list of all the computers accessing your network, and then you will be able to allow/deny each one as you wish. Admittedly I've never set up a wireless router, but I imagine it's the same as on my wired router.
Send em a message (if you can over a router) saying you have slept with their wife/husband.
When the angry party comes over, KICK THEM IN THE BALLS/TEETH
This saves you:
1) Hunting around houses to find the person
2) having to leave to comfort of you own home..
Either that, or download loads of child porn to their computer, and call the cops
Have you turned on the filtering?  If so it could just be a case of them being able to connect to the router, but being denied by it.
Theres no option too, so I assume its on. Also, sorry, I didn't mean trusted IP's I meant trusted PC's, I put the MAC address in there as instructed. I also setup the WEP, am I right in thinking any PC which wants to connect to my wireless will now need the passphrase I entered?How do I put this into the wireles adapters used ony my dad's and sister's laptop!Any way, the wanker seems to not be sucking up any of my juice now!!Thanks a lot!! :huh: :D (Y)
Theres no option too, so I assume its on. Also, sorry, I didn't mean trusted IP's I meant trusted PC's, I put the MAC address in there as instructed. I also setup the WEP, am I right in thinking any PC which wants to connect to my wireless will now need the passphrase I entered?How do I put this into the wireles adapters used ony my dad's and sister's laptop!Any way, the wanker seems to not be sucking up any of my juice now!!Thanks a lot!! :D  (Y)  :P
You need to:
Go into the router setup ( www.routerlogin.net I think :huh: )
Click on Advanced Wireless Setup in the firewall main menu
Under Wireless card access list, click Setup Access List
Tick Turn Access Control On
Select a card, then click Add
When you've done all the cards you want to do, click Apply
Report him to the police. It's against the Law, I was speaking to my uncle about his network at the weekend, and he was saying how he prosecuted a guy who had been stealing WiFi connection from a neighbor. (He's a barrister.) Soon sort him out. :huh:
There's no specific law about it at the moment. Although I think it would be against the law if you asked your neighbour not to use your internet and he still did. Kinda like having a big field and no gates or something. People can wander through and frolick in the fields. But then if you put up a "No Trespassing" sign, it'd be illegal. The chance of anyone getting into trouble = very slim though, unless they were doing something really bad.
Bear in mind that you can wander over to various hotspots and get it for free anyway. In fact I have heard of people with their own wireless setup connecting to nextdoor's by mistake. Their connection dropped and their computer picked up nextdoor's connection and started using it without saying a word, the user didn't even know. IMHO, if someone's stupid enough to leave their internet open to outsiders, they should expect some people to use it.
we have a company called shenstone business systems that set up our work places entire wireless network, i shall ask them what they suggest doing and they will have a good answer for you, i shall ask them sometime tomorrow and post up the reply that they give me.
stu (Y)
Thanks man!Thanks everyone for your help!For now,it seems the problem is remedied.
Right, i have spoken to our technical manager and he said:
You should have some sort of console for your wireless router. On your console (the program that operates the router) you should have an option to login. The passwords and username are usually set to the defaults and should be able to be located within the manual you got with your router.
Once you are logged in to the console you should have a button or a tab that says "wireless" or something similar.
Within that there should be an option for encryption which allows you to apply either a 64 bit or 128 bit key.
You then need to configure your wireless connection so that when you connect your key is right and accepted and this should stop anybody from being able to break the code and should give you and only you the access to your internet connection.
Hopefully that helped a bit, stu :P
