Luke_bradley Posted August 17, 2005 Report Share Posted August 17, 2005 Just built myself a new bike up, and have ordered a wider rim. The only thing left for me to do now is to sort my gears and mech and shifter out. At the moment i have got an xt hum with a 7 speed cassette. I know i need a short arm mech and i've seen trials gears but i dont know what to get. What do you thing i should get. I am willing to spend about £50. Cheers, Luke :P Quote Link to comment Share on other sites More sharing options...
mad_gavo Posted August 17, 2005 Report Share Posted August 17, 2005 just go for something fairly cheap like shimano tigra or sora short cages they do the job and you dont cry too much if you hit them :P there about £15-£18 from most bike shops As for the cassete just go for something with a range from bout 21t to 12t then you have a nice range of gears at a reasonable weight. again shimano sora, tigra and 105 are good bets and can be got in 7, 8, and 9 speed i belive and are about £18 So you can get a good setup for about £40 :) just add a thin KMC kool chain and your away :) Hope that helped Gavin Quote Link to comment Share on other sites More sharing options...
Janson Posted August 17, 2005 Report Share Posted August 17, 2005 tiagra is the shit. tiagra mech, random cogs and spacers of different sizes, and a 90's style thumb shifter is the way to go. fully comp legal in every country, easy to shift, easy to fine tune mech because of the friction shifter, so if you get a minor knock on the mech you can just compensate at the lever. also looks awsomely pimp with a big black thumbshifter on the bar. Quote Link to comment Share on other sites More sharing options...
MikeWarner Posted August 18, 2005 Report Share Posted August 18, 2005 (edited) I've just bought a load of Sram stuff. One reason for this is that the low end stuff is much lighter than the equivalent Shimano stuff. The rear mech is mostly made of a resin plastic so should bounce back after knocks. The 8 speed roadie cassette (23-12) is very light compared to a shimano one and looks stunning quality. The shifter is a 2 trigger type, but it uses a 1:1 shift ratio making changes smoother and adjustment more acurate. The rear mech, cassette and shifter came in at under £60 the lot, so items are cheap to replace. I have yet to fit it all, so I'll update with performance at a later date, but from what I've read, it should be really good. Oh - and it is a bit different to the usual Shitmano stuff people use. :P Edited August 18, 2005 by MikeWarner Quote Link to comment Share on other sites More sharing options...
JIX Posted August 18, 2005 Report Share Posted August 18, 2005 Do you enter national comps, or will do in the future?? If no I would go single speed, unless you really want gears? I hate my gears and they are so much more hassel than they are worth. If I were you I would get a gusset thick chainring, then a gusset single speed sprocket on the back, and a thick kool chain. Then buy a tigra mech, space the jockey wheels out a little bit with some washers (for the chain), lock it out, and then line it up and lock it in place with a short pice of cable. Then you will be laughing. :P I really want to do this again. Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted August 18, 2005 Report Share Posted August 18, 2005 Sora mech, 105 cassette and an alivio shifter. They work a beast on my jump bike Quote Link to comment Share on other sites More sharing options...
matthewholdsworth Posted August 18, 2005 Report Share Posted August 18, 2005 go for a tiagra/sora/105/ultegra/dura-ace rear mech they are short cage and have a tighter spring to give them more tension, i use tiagra, it is better than the sora because the cable is held in with an anllen bolt not a 9mm nut thingy (much nices and easier to sort when out on a ride) Quote Link to comment Share on other sites More sharing options...
Littleharrys Posted August 19, 2005 Report Share Posted August 19, 2005 just go for something fairly cheap like shimano tigra or sora short cages they do the job and you dont cry too much if you hit them (Y) there about £15-£18 from most bike shops As for the cassete just go for something with a range from bout 21t to 12t then you have a nice range of gears at a reasonable weight. again shimano sora, tigra and 105 are good bets and can be got in 7, 8, and 9 speed i belive and are about £18 So you can get a good setup for about £40 (Y) just add a thin KMC kool chain and your away :P Hope that helped Gavin ← Yeah pretty much what he said. I run a sora mech, 8 speed cassette starting at 25 tooth going down in 2's and XT shifter. Don't spend loads cos you will break it. I have already broken 2 mechs and a shifter. Go wiith cheap and cheerful. H Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted August 19, 2005 Report Share Posted August 19, 2005 Back in the day of gears on my trials bike I had/still have a shimano 105 road mech which was/is brilliant! and a shimano rapid fire shifer and a 105 cassette (Y) Awesome set up (Y) Quote Link to comment Share on other sites More sharing options...
IOLO Posted August 19, 2005 Report Share Posted August 19, 2005 (edited) i use a steel mech from the tip with lots of holes in,, and alu thumbshifter from a rusty skip with the bar clamp rewelded bigger so it fits my seat tube,, and a few cogs off old cassettes put together on my hub in a mess... works fine and is fairly light Edited August 19, 2005 by IOLO Quote Link to comment Share on other sites More sharing options...
_skj0lsvik_ Posted August 19, 2005 Report Share Posted August 19, 2005 Shimano 105 short cage mech, shitty cassette and a Shimano XT deore shifter (Y) Works brilliant : ) Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 19, 2005 Report Share Posted August 19, 2005 On the trials bike: Tiagra mech, King Kog + Hyperglide cogs, KMC Thin, XTR cabling, Sram Rocket/Attack shifter. On the 4X bike: Sora mech, Sora cassette, XT cabling, XT shifter, PC99 chain. Cheaper is better usually... Well, for the avarage rider anyways. If you wanna ride like Vince, you will need to buy a 330 Euro Tigo/Try-All mech. Quote Link to comment Share on other sites More sharing options...
Koxx_TryAll Posted August 19, 2005 Report Share Posted August 19, 2005 Well i'd go for a Shimano Rx100 Mech. Well that's what i use. I Made my own single speed kit. You should do the same. Nick Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted August 19, 2005 Report Share Posted August 19, 2005 i use a shimano sora mech, it's had a fair few nocks and it's still running smooth. ben (Y) Quote Link to comment Share on other sites More sharing options...
george_bush Posted August 21, 2005 Report Share Posted August 21, 2005 tigara are loads more better my old sora mech exploaded. Quote Link to comment Share on other sites More sharing options...
