Control Riders
Ben Swales
i've been having real problems setting my brake up on my echo control ('04 model) using the control booster. it's so big it gets in the way!!
so i took it off, and managed to set the brake up fine. the only problem is that there's 1-2mm of flex at the piston, which translates to (from what i can see) abou 1cm of flex at the lever...
what i'm wondering is, how many people who ride the 04 control run their brake without a booster, and have they had any problems with it? and does anybody else find it really tricky to set up the brake with the control booster, or am i just cackhanded?
cheers
The Control booster fitted my T-Pro, but it was so big and bulky it was a whore to set up like you described. Try getting the Team booster instead :P Only does the top two bolts, but it's hella stiff so it's all for the good.
cheers mark, i might do that. i should be getting some hope braided magura hosing at the start of next week, which i'll need to take to the shop to get fitted, might get them to set the brake up with the booster while they're at it, save myself the ballsache. i'll look into the team booster though. will it definitely fit the control?
yup it will definatley fit, my mate uses a team on his control
