Ouchhhhhhhhhhhhhh....
Joe Papasnap Maher
Use sensative tooth paste. It really does work.
LMAO Unfortuantely it doesn't treat toothe ache! There is a bit of difference between that and sensitivity.
Best idea would be to dope your self up on asprin untill you can get to a dentists. Act like a scrounging student and you might be able to get pro-bono work for free! (Y) It will probably be a root canal cavity, so it will be under the gum. Painful as f**k, prety expensive aswell.
And a dentist can put anyone on the NHS for a check-up, book a check-up.
