Onza Kieron Posted August 11, 2005 Report Share Posted August 11, 2005 My mate has been lending me a Hope Bulb on the rear and it scares me. You can only run the QR very loose or it seems to jam the freehub n stop it from freewheeling. Also the bit where the cassette slides on just pulls off without much effort resulting in fast travelling pawls :D Anyway,any help appreciated, Kieron :P Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted August 11, 2005 Report Share Posted August 11, 2005 Take your cassette off and shove a spacer on the freehub. Will be as good as new :D Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 11, 2005 Author Report Share Posted August 11, 2005 Do you mean on the end of the axel? :"> Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted August 11, 2005 Report Share Posted August 11, 2005 Freehub :D The spinny clicky bit that the cassette goes on Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 11, 2005 Author Report Share Posted August 11, 2005 But where lol do you have msn(kieronbaister@hotmail.com) if not cud u just bang a lil piccy up because i dont know where you mean on the freehub,do you mean behind the cassette? :D Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted August 11, 2005 Report Share Posted August 11, 2005 Behind or in front it dosent matter Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 11, 2005 Author Report Share Posted August 11, 2005 Sorry but i have no idea where you mean. Do you mean if I was to take the cassette clickey bit offand the pawls would come out put it on there against the bearings then put the block back on?Sorry im a bit slow, im tired. Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted August 11, 2005 Report Share Posted August 11, 2005 Take the cassette off the freehub not the freehub off the hub body. You need a chain whip and a cassette tool to get it off. Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 11, 2005 Author Report Share Posted August 11, 2005 Yeh then put a cassette spacer on? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted August 11, 2005 Report Share Posted August 11, 2005 Yup. Put a spacer on then shove the cassette back on and tighten it all up Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 11, 2005 Author Report Share Posted August 11, 2005 Ah ok thanks for the replies without getting angry :) Ill give this a blast tomorro. :P Kieron :D Quote Link to comment Share on other sites More sharing options...
The Dude Posted August 12, 2005 Report Share Posted August 12, 2005 sounds like your axle is snapped mate, check by pulling it, if it slides off with the freewheel, you need a new one. dont worry about the freewheel coming off, its meant to for servicing, just whack some chain oil in there and put it back together (pawls the right way round and use the seal to hold them in pace when putting it back in) if in doubt, or its completely fooked, ring hope the'll sort you out a good'n. sorry about the wording, its too early, im off to work. Quote Link to comment Share on other sites More sharing options...
Caleb Posted August 12, 2005 Report Share Posted August 12, 2005 Try and do the method jay said but with like a 12 7 cog as that will (when revesed) give the lockring something to grip to instead of digging into a plastic cassette spacer Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted August 12, 2005 Report Share Posted August 12, 2005 If doing the QR up tight jams the freehub, try replacing the aluminium bush that sits on the axle between the freehub and the hub body, or try rebuilding the hub without the rubber seal. Quote Link to comment Share on other sites More sharing options...
