Small Crack In My Maggy Leaver Cover...
bquamb
I have a small problem. Maby its big but i dont know so im asking you guys.
There is a small crack right by the bolt. I dont know how to fix it if it is fixable.
Ill try to get a picture for you guys to see.
How much would 1 cost to fix? i know i haveto replace the whole thing.. ie: leaver, shell, inside, take the cable out and what ever else lol.
Please help :P (Y) :D :( :D :P :P
it should be alright for a while depending on which bolt it is and how bad the crack is, but i'd look in to getting a new lever body. Take a look in the for sale section, theres always someone getting rid of them. You wont need to replace the lever, or insides or cable.. just the lever shell since everything can be taken apart easy.
I've got quite a few Magura levers in Mark's Magical Magura Bag. All of them have snapped there, from downhill usage.
Anyway, if it's cracked there, eventually it'll just snap as you pull the lever or put force through it, meaning the lever will launch out and you'll have no brake power.
This isn't shit hot.
Try www.chainreactioncycles.com and see if they can help you out with anything, I believe they do Magura spares.
ive snapped two in the same place, never notice the cracks though..im always doing something and Bang!, lever falls off lol.
Rossi has done same afew times i believe, as spacemunkee said, just buy new shell. in my case i just bought a new body from mate, couldnt be bothered changing insides so just whacked lever onto new body and bleed (Y) (with water) :D:):(
I once over tightened the bolt that holds the lever blade onto the body, and the body snapped (Y) :D :( Well, it cracked, so i got a washer and a few other things and i made it work again, for about 2 months, then it fell apat, sent it off the magura and i got a new lever body for free (cause it was under warrenty) and it was mint again :D
Free magura oil bleed aswell :P but it had sooooo much fricken air in!!
