Onza Kieron Posted August 8, 2005 Report Share Posted August 8, 2005 I'm getting a Hope XC Ti and it need three pawls and three springs,the problem is i dont know where or how to get them. I've heard that Hope will replace them for free if I send the hub to them, is this true and if so when will I recieve it back because im going on a riding holiday next friday. Kieron, :) P.S I did try the search and i didnt find anything helpful. :huh: Quote Link to comment Share on other sites More sharing options...
rich4130 Posted August 8, 2005 Report Share Posted August 8, 2005 I tried blagging some, it didn't work. www.wiggle.co.uk is probably your best bet, very good delivery as well. Quote Link to comment Share on other sites More sharing options...
Tomm Posted August 8, 2005 Report Share Posted August 8, 2005 I believe you can order them from Hope through your local bike shop for £12. Or send the hub back. They will replace the pawls for free, but you'll have to pay postage and it might not get there in time. Not sure if you can order them direct from Hope, but it's probably worth a try (They might even send you some for free if you're very lucky!). Apart from that, I think you'll have difficulty finding anywhere that actually has them in stock, although you could try just ringing around several bike shops. EDIT: It appears that Wiggle have them in stock, although they call them Hope Paws :huh: Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 8, 2005 Author Report Share Posted August 8, 2005 It says Hope pawls but i also need the springs so does anybody know where I can get them or if anybody has any i can pay a small amount for? :huh: Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted August 8, 2005 Report Share Posted August 8, 2005 Chain Reaction sell pawls and springs for about 15 quid a set. Alternatively you could send the wheel to Hope. Sending a wheel is better as they can replace the ratchet ring. Last time I sent a hub on its own it was immediately returned with a note saying that they can't replace the internals unless the wheel is built (they need something to grab when twisting out the ratchet ring). Don't bother phoning or trying to 'blag'. Just send them the wheel. They pay return postage. Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 8, 2005 Author Report Share Posted August 8, 2005 Sorry im going on a bit now but whats hope's address and how much is it for postage? Cheers alot,Kieron :huh: Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted August 8, 2005 Report Share Posted August 8, 2005 Hope Mill, Skipton Road, Barnoldswick Lancashire, United Kingdom BB18 6EN About 5-7 quid. Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 9, 2005 Author Report Share Posted August 9, 2005 OK, im planning on sending the wheel to Hope but I was wondering, how much effort is it to fit pawls and springs, is it worth doing it myself and what tools do I need? Cheers again, Kieron (Y) Quote Link to comment Share on other sites More sharing options...
Heatsink Posted August 9, 2005 Report Share Posted August 9, 2005 I think it's just a screw driver to pop the end ring thing off (very little force needed) and slide the freewheel off (the lump the cassette sits on) you'll be amazed at how simple the internals are. Just some lumps on steel sat on springs. Couldn't be easier. The hardest thing is finding the old pawls and springs that have fired off into the long grass somewhere when you opened it up! Disassemble carefully with no sudden movement of the wheel to avoid this. I think that the springs in my Hope (2nd hand) are cut down ones from a biro! Search for "Hope hub spares" on wiggle for the complete list of spares Exploded view of the hub internals (pawls are #7) http://www.hopetech.com/technical/technical_index.htm Hub maintainance PDF: http://www.hopetech.com/technical/technical_index.htm Steve OK, im planning on sending the wheel to Hope but I was wondering, how much effort is it to fit pawls and springs, is it worth doing it myself and what tools do I need? Cheers again, Kieron (Y) ← Quote Link to comment Share on other sites More sharing options...
Wing Posted August 10, 2005 Report Share Posted August 10, 2005 I think that the springs in my Hope (2nd hand) are cut down ones from a biro! ← On closer inspection, you'll find that they are specially hand selected springs from the local mackay's hardware shop, they were more tightly coiled which should make them work more effectively :) It says Hope pawls but i also need the springs so does anybody know where I can get them or if anybody has any i can pay a small amount for? (Y) ← I got a set of pawls from my lbs (which will also includes springs), they don't usually stock them so may take a couple of days to order them. If you aren't sending your wheel off, i have a set of pawls and springs you can have for £12 (how much i brought them for) as i no longer own a hope hub. Quote Link to comment Share on other sites More sharing options...
LEON Posted August 10, 2005 Report Share Posted August 10, 2005 I have a full seT for sale, they were ordered but not needed, so unopened (Y) TENNER POSTED :) LEON Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 11, 2005 Author Report Share Posted August 11, 2005 Ok im now not sure whether im getting this wheel as the guy is fecking me around alot :P but if i do then we'll talk buisiness (sp?) LEON :D Kieron :) Quote Link to comment Share on other sites More sharing options...
LEON Posted August 12, 2005 Report Share Posted August 12, 2005 Whos the wheel off if u dont mind me asking? Is it a black xc on a ground 521 cd? :'( LEON Quote Link to comment Share on other sites More sharing options...
