What Viscosity?
JIX
What viscosity do magura recommend for their brakes?? Its in the manual but I wont be able to check before I go to buy some so if some one could look for me please :huh: i would realy appritiate it.
Also do you reckon if I went less viscious it would be better?
Im going to have to go to halfords to get it, so if you know of anything that they have. I have normally gone for citron car brake fluid which is mineral oil.
Adam do you know the viscosity of water?? I might go for something inbetween.
I think that water has a viscosity of 1.00 because that’s how they define the scale – Everything is given a rating relative to water (I think :huh: ). Apparently, you can get rubbing oil for cleaning brass (Ie. Musical instruments) that is 0.6 wt or something like that – almost half the viscosity of water. So that should be pretty good, if you can get hold of any, although I think it comes in tiny bottles that are about 5ml. Might be worth looking for if you’re that bothered?
Other than that, just use water, or any kind of mineral oil. It doesn’t really make much difference.
My magura is bled with water, I think it was you who reckoned it felt nice? :huh:
I take my magura to bits, clean the piston/lever with WD40, flush the hoses through with it, re-assemple, flush with water and then bleed.
Most of the inside of a magura is plastic anyway so I wouldn't have thought it would do any harm, mine seems fine anyway.
Can I flush the maggie oil out without taking my brake apart? I want to bleed it with water but I don't have an 8mm spanner to screw all the hoses off and I'm not excited of the idea of taking the brake off my bike and setting it up again later etc.
Thanks.
Thanks.
Yeah, either just pump loads of water through the system, or attach your pump to the bleed pipe thing and pump loads of air through quite fast.
I took mine appart and bled it and flushed it though with water loads of times with water over a period of about 6 months. Yet when i decided to take the piston out the lever it was still full of manky water/oil mixture. Your best bets probably a track pump or an airline.
i used a pump to blow all the oil and stuff out. bleed through a few times with tap water and you'll get the manky crap from the seals off. then just bleed it.
also, bleeding with water is a 5 minute job. also, not messy at all, after all, it's just water!
I use water in my brakes and so does ben and all the other lads that i know, its really good but the only problem is tha after a while you have to watch the calipers becayse they start to seeze up so you have to service them to keep them sweet. (Y)
I use water in my brakes and so does ben and all the other lads that i know, its really good but the only problem is tha after a while you have to watch the calipers becayse they start to seeze up so you have to service them to keep them sweet. :)
as dan said... use water... but bleed it will oil every now and then to stop the seals dying and drying out..
Try bleeding it wit cooking oil... it makes it VERY VERY slow!! lol
but it lubes up the whole system! and then re-bleed with water again :)
i might take mine apart and blow it through with the compressor :) just to see if my brake goes any fast... oh and i better get some de-ironised water to bleed them with. just to be on the safe side :)
