Magura Rear Brake, Hs33?
charlie_H
:huh: go for the hs33 i have the new 05 ones! there great! :D
if you get them though get some new pads because the standard ones arent up to much! :P"
but if you cant afford any pads just use a fair bit of rim tar for the time being!
hope this helps (Y)
ollie
  • 2 months later...
ok you said there was only 1 bolt in the picture you see that oval secion of the brake just a bit further up that is where the 2nd bold will go in to your frame.
This is there so you can move the brake up and down so it fits with the biggest surface area in contact with the rim.
You want a HS33 they are so much better, and no i wouln't bother with braided hosing though many may disagree get a booster that covers the cross ova so you dont stand on it when doing crank spins or catching it, i think that works does on mine
