Pashley
george_bush
Aint that the older pashley?
if so there welded to the frame so you would have to get anew one welded on if yours snapped.
if its the mhz the new one then have a look on tarty or select bikes or supercycles and see if they have the correct one (Y)
is that not the leeson style hanger??????
pashley never made it "their standard hanger" they (i think) only used it on the proto type frame/s. so i you have a prototype frame then you need to contact either leeson or a home bodge is in store. or you could go see your local engineer and ask him to knock you 2/3 up.
Waynio.......................
