Small Axles In A Base Ta26 Frame
Krisboats
right, i'm posting this for conner (gap to manual) because his internet is gayed up. basically he got a new frame, came round my house to swap the parts over and use the crank extractor and when we put his rear wheel in, the hub is mega tiny and the QR skewer pulls his dropouts in by about 1cm before it's even touching the ends of the hub.
Basically he needs to know if this will cause any long term problems and if it's possible to whack a bigger axle in there.
The wheel is too far over to one side of the frame as a result as well, the tyre nearly rubs on the frame.
cheers
kris
Hmm , I know that my TA26's rear triangle gets "pulled" in about 5-7 mm when tightening a Q.R , the dropouts kinda seem to sit wider than is neccesary . :P
What hub is Conner using ? If , as you say , the dropouts are only beginning to touch the ends of the axle after 1cm of movement , that doesn't sound healthy , given the stresses placed on them during riding . You say the frame is new - to him , or shop new ? It's a new TA26 right ? Not the previous version with the strut betwen the top and downtube ? Kinda curious about this , keep us posted .
dont forget these frames are made in like 100's and 100's so the tolerances as long as it meets their criteria wont be a problem, and to be honest it is usually "Tolerances" are checked in the UK and they may not be checked. so there may be a batch of them that are a few mm out more than the others.
Waynio........................
