Trials Boy Posted August 5, 2005 Report Share Posted August 5, 2005 I have a Hope Mono M4 at the moment and COULD upgrade to a Mono Trial, would this be worth it? Are there any differences? Hope Mono M4 180mm Hope Mono Trial Thanks :P Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted August 5, 2005 Report Share Posted August 5, 2005 Just stick with what you've got. You've not been riding very long have you? You dont really need to upgrade to a super brake yet as your probably not doing front wheel gaps and stuff. Quote Link to comment Share on other sites More sharing options...
Trials Boy Posted August 5, 2005 Author Report Share Posted August 5, 2005 Just stick with what you've got. You've not been riding very long have you? You dont really need to upgrade to a super brake yet as your probably not doing front wheel gaps and stuff. ← I been riding 7 months but i'm young, i see what you been, and no i dont do front wheel gaps yet. Cheers for your help :P Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted August 5, 2005 Report Share Posted August 5, 2005 if you feel that the monom4 is lacking in power, have you thought of buying some disk brake cleaner? only costs a 5er and may de-contaminate the pads/rotor for you :P ta Quote Link to comment Share on other sites More sharing options...
Trials Boy Posted August 5, 2005 Author Report Share Posted August 5, 2005 if you feel that the monom4 is lacking in power, have you thought of buying some disk brake cleaner? only costs a 5er and may de-contaminate the pads/rotor for you :P ta ← It is losing power, but where can i get this Disc Brake Clear from? Quote Link to comment Share on other sites More sharing options...
Dr. Nick Riviera Posted August 5, 2005 Report Share Posted August 5, 2005 It is losing power, but where can i get this Disc Brake Clear from? ← taps , and on a brief occasion the sky :P Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted August 5, 2005 Report Share Posted August 5, 2005 you can get disk brake cleaner from wiggle.co.uk i have some on order, you can either get the muc-off or another sort which i can remember the name of :P Quote Link to comment Share on other sites More sharing options...
Punkrider Posted August 5, 2005 Report Share Posted August 5, 2005 Hope Shit Shifter Adam Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted August 5, 2005 Report Share Posted August 5, 2005 Hope Shit Shifter Adam ← leaves a residue.... use the disk brake cleaner, its what its been designed for... hope shit shifter has been designed for shifting shit :P Quote Link to comment Share on other sites More sharing options...
Punkrider Posted August 5, 2005 Report Share Posted August 5, 2005 leaves a residue.... use the disk brake cleaner, its what its been designed for... hope shit shifter has been designed for shifting shit :P ← It is ment for discs :P Many cleaning products contain silicon, polish or other additives which have a detrimental effect on disc brakes. Problems caused range from squealing to total loss of power. We realised that the only way to stop these problems would be to produce our own range of cleaners. Sh1t Shifter is the first of these products. It is a bike wash which has been specially formulated to be safe for use on disc brakes, anodising and painted surfaces. It is available in 1 litre containers, all supplied with trigger sprays and of course comes in Hope green. Quote Link to comment Share on other sites More sharing options...
Chris Cook Posted August 5, 2005 Report Share Posted August 5, 2005 Stick with the brake you have got untill you start impoving very good then upgrade. You should be defo able to get disc cleaner from you LBS! Check there or get some muc of disc cleaner form CRC Chris :P Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted August 5, 2005 Report Share Posted August 5, 2005 It is ment for discs :P Many cleaning products contain silicon, polish or other additives which have a detrimental effect on disc brakes. Problems caused range from squealing to total loss of power. We realised that the only way to stop these problems would be to produce our own range of cleaners. Sh1t Shifter is the first of these products. It is a bike wash which has been specially formulated to be safe for use on disc brakes, anodising and painted surfaces. It is available in 1 litre containers, all supplied with trigger sprays and of course comes in Hope green. ← its use isnt to clean disk brakes thou is it? who cares, he either takes yours or my advice, i know which i would choose out of the two options(shit shifter, or disk brake cleaner) to clean my disk brakes :P" Quote Link to comment Share on other sites More sharing options...
Punkrider Posted August 5, 2005 Report Share Posted August 5, 2005 Hope Shit Shifter is designed to remove the shit from the disc, it even has disc logos on the label :P" Adam Quote Link to comment Share on other sites More sharing options...
