Hope Enduro4 Caliper + Luise Fr Lever =
Will Arnold
I think the two systems use different oil (Hope=Dot, Magura=Mineral oil).  And that's if the piston diameters are compatible...
Why?  :P
piston diameter, pah!
i have a leaky enduro leaver :P"
and i thought i would play with some setups to get a beasty brake going...
no worries if the brake fluid isnt the same i will leave it for now...
ta
Will
hope now do mineral oil seal kits!
that could be an idea, they designed these so that people could use the new shimano levers with brake and gear in one with a hope disc calliper rather than the shimano
(Y)
ash
sounds good :D
too late i already have the enduro seal kit to fix the porblem :P
ta
