Will Arnold Posted August 4, 2005 Report Share Posted August 4, 2005 the brake already has dot 5.1 brake fluid in it i believe, would it harm the system if i top it up with dot 4 ? because i dont have enough dot 4 to fill the system and get the air bubbles out if you see what i mean... please help trisha (Y)" Quote Link to comment Share on other sites More sharing options...
Danny Posted August 4, 2005 Report Share Posted August 4, 2005 Your supposed to flush the system out and use one or the other but i doubt it would matter if you mixed the 2. Dot 5.1 just has a higher boiling point. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted August 4, 2005 Author Report Share Posted August 4, 2005 Your supposed to flush the system out and use one or the other but i doubt it would matter if you mixed the 2. Dot 5.1 just has a higher boiling point.← is that the only diference thou? ta Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted August 4, 2005 Author Report Share Posted August 4, 2005 ah feck, i may aswell just try it (Y) Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 4, 2005 Report Share Posted August 4, 2005 is that the only diference thou? ← Dot 4 is less prone to ingress of water... and since it doesn't really get hot for trials, you might as well bleed it fully so its got Dot 4 in it (Y) Quote Link to comment Share on other sites More sharing options...
