Quick Grind Question.
Joe_Elding
Well I grinded my rim for the first time yesterday. I think it's quite harsh. Anyway it works really well when going forward but when going backward it holds like coolstops in the wet with tar. My pad combination is Plaz crm's on a hog rim.
I'm thinking it's 'cos of the angle I grinded at?(Quite shallow angle)
So if I held it closer to right angles with the rim would it work better going both ways?
Or maybe it's just beacuse I went clockwise?
So would it work if I grinded one side of the rim clockwise and the otherside anti-clockwise?
Any opinions needed.
Cheers
the way i see it, if you drag your brake down a big hill going forwards, your brake is going to be immense at locking forwards, but not backwards, if you drag it backwards then the opposite happens...
think its to do with the way the pad material.when transferred, sits behind each slice(couldnt think of a better word :blink: ) of the grind.
please dont shout at me if im wrong hahah
As tart said, make sure that the pads are aligned straight against the rim and secondly make sure that the pads don't have round edges, it makes the brake slip. if you got round edges just sand the pad down or something so that the pad is straight and have fairly "sharp" edges.
how does the sharp edges make the brake more powerfull?
