mr ailsbury Posted July 31, 2005 Report Share Posted July 31, 2005 Hi guys, The chain on my T-Pro keeps jumping off the teeth randomly when im pedaling along and i dont know whats causing it because i have my chain at the right tension etc and its really getting on my nerves!!! :bunny: Have any of you lot had the same problem or do you have any advice on how i could fix the problem? cheers, ToM Quote Link to comment Share on other sites More sharing options...
hazzyhaslam Posted July 31, 2005 Report Share Posted July 31, 2005 Check you ain't got a twisted link or summat like that. Does the chain have a stiff link? Worst case, Is the frame twisted? Quote Link to comment Share on other sites More sharing options...
Koxx_TryAll Posted July 31, 2005 Report Share Posted July 31, 2005 For your Chain. Did you use the missing link that comes with it? If so Check to see if its the right way round. Chears Dude. Quote Link to comment Share on other sites More sharing options...
totaltrials Posted July 31, 2005 Report Share Posted July 31, 2005 Chain line maybe, try offsetting the bottom bracket on the driveside to get a better line. Phil. Quote Link to comment Share on other sites More sharing options...
Sponge Posted August 1, 2005 Report Share Posted August 1, 2005 Could well be chainline problems, in that case, obviously run a shorter Bottom bracket... or the chain is upside-down if it's a KMC Kool Chain, because upside down means there's a bigger space between links for KMC Kool Chains so it skips and screws up more frequently... Just try everything, buy a new chain if necessary too.... and if you can, try avoiding usage of split links... They tend to be more fragile than normal links. Quote Link to comment Share on other sites More sharing options...
