nb88 Posted July 25, 2005 Report Share Posted July 25, 2005 Just got a set of echo team forks and set it all up perfect......put my disk on, the rotor rubs on the top of the caliper :turned: :D . Its a magura louise disc with the standard rotor and the wheel and everything is all in properly.. is there anything i can do about this? thanks, noz. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted July 25, 2005 Report Share Posted July 25, 2005 1) Loosen all rotor bolts by half a turn. Grab the rotor by the 'arms', and rotate it anticlockwise, while you tighten the bolts up. The centres the rotor on the hub. 2) Put bike upside down, loosen caliper bolts, and pull the caliper away from the hub by hand. Then tighten the bolts again while keeping the caliper held in that position. That should help, if not, shout back :turned: Adam Quote Link to comment Share on other sites More sharing options...
RobinJI Posted July 25, 2005 Report Share Posted July 25, 2005 Try spining the wheel while holding a file against the outer edge of the rotor until it stops rubbing. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted July 25, 2005 Report Share Posted July 25, 2005 Try spining the wheel while holding a file against the outer edge of the rotor until it stops rubbing. ← :turned: just do what tarty says :D Quote Link to comment Share on other sites More sharing options...
nb88 Posted July 25, 2005 Author Report Share Posted July 25, 2005 Cheers tart, sorted! Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted July 25, 2005 Report Share Posted July 25, 2005 Try spining the wheel while holding a file against the outer edge of the rotor until it stops rubbing. ← Are you f**king mad!? Quote Link to comment Share on other sites More sharing options...
JT! Posted July 25, 2005 Report Share Posted July 25, 2005 1) Loosen all rotor bolts by half a turn. Grab the rotor by the 'arms', and rotate it anticlockwise, while you tighten the bolts up. The centres the rotor on the hub. 2) Put bike upside down, loosen caliper bolts, and pull the caliper away from the hub by hand. Then tighten the bolts again while keeping the caliper held in that position. That should help, if not, shout back :D Adam ← Try spining the wheel while holding a file against the outer edge of the rotor until it stops rubbing. ← Perfect example of brains and bronze. :turned: Quote Link to comment Share on other sites More sharing options...
