Juicy Seven Review
Mr Motivator
I'd been using an avid BB7 for a year and a half with an XTR lever and XTR cable. The set up was perfect although there were a few problems over the course of this time;
- Too much bite for gaps to front wheel
- Heating up quickly so there is no bite at all
- The adjuster knob falling off
- The adjuster knob being so far out that if you fail something you could knock it off
- The caliper arm bending.. twice, just under the force of my finger
- The caliper arm flexing, so your lever feels all flexy
- The internals randomly springing out
- Not much modulation
- The adjuster knobs no longer clicking
Well after this 18 months, THIS happened. I was standing over my bike not even touching the brake and suddenly the internals popped out and were spewed all over the floor like guts. I put it back together that night and found the cause of the problem being a small nut that had worked loose under the outboard pad adjuster after having being turned many times during the set up. This was all prior to the knob no longer clicking when its turned, so if your knobs don't click I strongly advise to flip them off with a screwdriver and tighten those nuts before you have an accident.
Anyway, I ordered myself an Avid Juicy Seven DH 185mm at £129.99 from CRC. I got it this morning and after struggling with my grips, managed to have it all set up within about 2 minuets.
The power at first was dreadful as expected but as the pads wore in the true power of this brake was reveled. I found that there is just as much bite as the BB7 as they have the same pads but more modulation due to the fact of them being 2 pot (both pads move inwards unlike only one pad on the BB7).
Advantages over BB7;
- Easyier and quicker to set up
- 2 pot
- Has a TPA so you can adjust how much you want to pull the lever back
- Has a lever reach adjuster
- Pimper rotor
- A flippable lever that works on either side as you can pop all the gubbins out and put them all back in the other way
- Doesn't stick out to the side of the forks so there is nothing to knock off
- Loads more modulation
- Just as much bite
Advantages over other hydro disks;
- Megga adjustability in the caliper and lever
- Awesome bite
- Awesome lock
- Nice feeling lever
- Power doesn't fade no where near as quickly
- No flex at all
Gaps to front wheel are much nicer and mainly everything feels a little nicer. The fact that you can adjust the lever so that it'll put back as much as your magura is great and there is no more flex!
Some piccys to wet yourself over;
Nice and neat, rotor a little grubby but once that washes off it'll be even better.
Nothing protrudes from the side of the forks so there is nothing to knock off.
Lush lever.
So if you happen to have 130 quid for a disk and don't know what to get, I definitely recommend one of these :-
Sam
ah sounds good that, i have found thats the problem with hopes is that the little brass grub screw thing allways seemed to screw out. or has the avid still got this and the dial actually does something different all together?
would there be any need to go for the 203 over the 185?
No, it 'clicks' when you turn it. Every click equals 1mm of lever reach.
185 is fine. Its smaller too so less chance of twatting it and smaller looks better :-
Pads dont wobble either :D
Advantages over BB7
Thanks for the review, but the bb7 does sort of have a tpa, the knobs at the bottom. And the two other points are about the leaver, which has nothing to do with the brake itself, and even if you do have the avid SD leavers they have a reach ajuster and work on both sides. Not trying to be a tit, but i just though i'd point it out.
Aparently they leaver has a very unique feel to it. What's it like?
Edited by JT!
The fact that is has a TPA unlike any other hydro disk out there makes it rather unique. It means you can pull both levers back as far as each other so your back and front brake feel nice and even, and the flip over design is a great idea (bolts and TPA pop out and go on the other side so you can either use it moto style or just normal)
The actual leverblade does feel very nice though, its pretty much the same as a CNC magura leverblade but it a weeeeny bit fatter so doesn't cut in as much when you pull it hard.
You can adjust the hope mono trial to pull into where you want it, so that both your levers pull to the same point. I wouldnt use it if you couldnt.
Plus the hope adjusts pad wear automatically so no need for a tpa. I havent had any problem with the screw coming loose or moving like james has.
It is a very good point that the lever blade is a very similiar shape to the mag, keeps the feel consistent.
Not knocking your review just pointing out some things. (N) (N)
i wonder which of the two brakes you have tried? (N)"
nice review sam, you sponsored by avid or something? (N)
ta
but that is to adjust lever reach.......the sooner you set the brake to come on the further away the lever is
im very tempted by this avid brake, as im now having troubles with my setup (N)
ill just see how long it lasts with your abuse (N)
