Grip Shift
Ducko
yelo,
right this may sound stupid, but i have been given a grip shifter and wants to run gears on my bike,
one problem and that is i dont know where the damn cable goes on the shifter ive never done one before,
the model is sram grip shift max-80 if that helps?
any advise=thanks
cheers
craig :rolleyes:
There should be a little hole somewhere on the shifter, just bigger than the metal lump on the end of the cable. Typically, activating either top or bottom gear will open it (it does vary on model). You may have to splay the little cover between the "grip" part of the shifter (where your hand goes) and the actual internals part though (the fixed part), depending on the model again...
