aaron_trials _247 Posted July 16, 2005 Report Share Posted July 16, 2005 (edited) how Easy are they to fit step by step guide to bleeding please and step by step guide to fitting also would be nice please DAN thanks in aadvance also will you be able to cut open some braided hose and put a splitter in line? Edited July 16, 2005 by aaron_trials _247 Quote Link to comment Share on other sites More sharing options...
picki Posted July 16, 2005 Report Share Posted July 16, 2005 there not easy to fit at all...infact there near impossible....unless you have some dodgy tool that does it. bleedigs piss easy....just do one side...tithten it all up, then do the other side and heypresto.... i had to refit mine and have ended up getting a new hose set...far too much hassle. Quote Link to comment Share on other sites More sharing options...
aaron_trials _247 Posted July 16, 2005 Author Report Share Posted July 16, 2005 do yo heat up the hosae a little? DAn Quote Link to comment Share on other sites More sharing options...
grantham Posted July 16, 2005 Report Share Posted July 16, 2005 take a look here there is a special tool to fit them, the monty stand in sweden had them but I havent seen them here, give barbara a call. Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted July 16, 2005 Report Share Posted July 16, 2005 If it aint broken, dont fix it. Quote Link to comment Share on other sites More sharing options...
aaron_trials _247 Posted July 16, 2005 Author Report Share Posted July 16, 2005 it aint broken i want one DAN Quote Link to comment Share on other sites More sharing options...
F-Stop Junkie Posted July 16, 2005 Report Share Posted July 16, 2005 That 'tool' being the barb fitting tool, or two pieces of nylon with a groove in the middle? Any magura dealer can get them. Quote Link to comment Share on other sites More sharing options...
cleanbikes Posted July 16, 2005 Report Share Posted July 16, 2005 Section7 said: That 'tool' being the barb fitting tool, or two pieces of nylon with a groove in the middle? Any magura dealer can get them. ← No, there is a special tool for fitting the Monty brake splitters - but I think you need expert training on how to use the tool !!! Quote Link to comment Share on other sites More sharing options...
dave33 Posted July 17, 2005 Report Share Posted July 17, 2005 clam the hose in the vice via the nylon blocks and hammer the barbed end into the hose thats the way i do it they can be a fanny some times dont bother heating the hose up Quote Link to comment Share on other sites More sharing options...
aaron_trials _247 Posted July 17, 2005 Author Report Share Posted July 17, 2005 i found a way of fitting the barbed ends in black hosing and figured that it will be the same for a splitter and my way is easy heat gun (600 odd degreees that i stole off my dad) (Y) heat up fitting for a couple of miniutes push real hard on the hose abra cadabra fitted (Y) and in under 10 mins DAN would this work for a splitter if it worked on fittings? Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted July 17, 2005 Report Share Posted July 17, 2005 does that heated up fitting not leak when put into normal trials action? mine leaked when i heated it up in boiling water as it was to much expansion. Tom Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted July 17, 2005 Report Share Posted July 17, 2005 (edited) Just put a tiny drop of washing up liquid down the tube, it makes it slippy, then just slightly tap the barbed head in, works easily Edited July 17, 2005 by terror-error Quote Link to comment Share on other sites More sharing options...
