saracen--mad Posted July 11, 2005 Report Share Posted July 11, 2005 (edited) Hey i recently went stock and i am finding it hard to set one side up one is perfect but on the left side the cylinde is as far out as it goes and the tpa is wound right in. Help please. Thanks Matt P.s the black joint things are both in the same place u no the bit where the bolt goes through he mount and screw into the black thing. Dont no the tchinical name. Edited July 11, 2005 by saracen--mad Quote Link to comment Share on other sites More sharing options...
N.Wood Posted July 11, 2005 Report Share Posted July 11, 2005 What frame/rim combo are you using? Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted July 11, 2005 Report Share Posted July 11, 2005 are your pads really worn, are the mounts the wrong way round ? Quote Link to comment Share on other sites More sharing options...
philking Posted July 11, 2005 Report Share Posted July 11, 2005 Just push the left hand cylinder through the clamp a bit more, ie closer to the rim, also make sure the black bits of plastic (elbows as i call them) are set so they touch against the inside of the seat stays, if they are not the brake will just pivot outwards at the top and not work... Quote Link to comment Share on other sites More sharing options...
