Leeson Custom Disc Rotor
joe b
Hellooooooo, i am going to be getting a Hope Mono trial soon on my new bike and the about 3/4 of my mates have bent theres causing it to rub quite badly and i cant be doing with that. Sooo, i want to buy a strong rotor. I was just wondering if the Leeson Custom disc rotor's were strong... and yes, i do know its just a Hope C2 rotor machined out, but C2 rotors look wank on theyre own so id get it machined out 'caus in my opinion it looks gorgeous! :)
Thanks in advance,
Joe.
When I got mine, I wasn't expecting any difference in strength. If you twat it into ledges and whathaveyou, you will bend it. Get used to bending it back.
One thing I noticed with my Leeson rotor though was that it would dig into logs and stuff when I was riding natural and stop it from bending. Very impressed.
Also, the rotor did improve the brake performance.
i have one it is sooo strong its ace!
obveously it bends when put under alot of pressure but mine it pretty straigh, i have wacked it a few times and thought ohh shit but it been fine!
defo a good buy :)
If it is just a C2 rotor then it will not be made out of different material to the rotors that come with the mono trial so it will be no stronger in that department. Also the fact it is machined out, ie less material, and therefore strength...
My hope trial is fine, just don't hit your rotor, if you cant manage that (like your friends by the sound of things) then don't get a disc. Its like riding without a bash guard it you know you are going to land on your chain ring a lot...
So to conclude, standard rotor is pleanty strong enough.
agreed!
mine is fine!!
go for a smaller size 160mm would be loads stronger and the 180mm and they seem to be rather powerful any how
They are all 160 :) . Any how i think i will be getting a Leeson rotor just for looks and 'apparently' brake performance! ...and also individuality!
Cheers,
Joe.
