Widest Mavic
JIX
I want to replace my front d521 with something wider.
I would like to stick with mavic on the front because they are awsome rims.
My d521 is 28mm wide I believe, so my question is;
What is the widest rim mavic do??
I have looked on websites but cant find many width's and weights.
If you could help out please. Links would be nice if poss.
front echo rims are pretty much the same as a 521 jamie so there is no point in changing to that if the only reason your changing is cause you want the width.
I will probaly get the 321 I was just wondering as I thought they were wider you ginger. But I dont want the weight, Im just going to drill the life out of it.
My arms are only Inflatable you know. :S
