cookie456_the2nd Posted July 1, 2005 Report Share Posted July 1, 2005 (edited) Right, i need to get my old acs claw off, and get my new one on, without the proper tool. I cant get hold of one at the moment, and arent the different to the standard freewheel removing tools? Any one got any ideas? EDIT: Right, i got the tool but the freewheel just wont budge, its on a wheel, not a crank so its not as easy to just put in a vice. any ideas? Edited July 3, 2005 by cookie456_the2nd Quote Link to comment Share on other sites More sharing options...
Swize Posted July 1, 2005 Report Share Posted July 1, 2005 (edited) Angle grind it off :( . Or I think theres a way when u undo the lock ring take everything out of the freewheel then clamp the bit that your left with in a vice and unscrew not to sure though. Sam Edited July 1, 2005 by samthebiker Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted July 1, 2005 Report Share Posted July 1, 2005 angle grind the outer part with the teeth on both sides untill it falls off in two halves, then angle grind two flats on the internal part, wack it in a vice then turn the crank :( Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted July 1, 2005 Report Share Posted July 1, 2005 good luck mate...you'll need it :( t'll be a challenge....the tool is only a few squid- and it'll last ages.. adam Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted July 1, 2005 Report Share Posted July 1, 2005 good luck mate...you'll need it :( t'll be a challenge....the tool is only a few squid- and it'll last ages.. adam ← bloomin easy with an angle grinder and a vice :( Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted July 1, 2005 Report Share Posted July 1, 2005 hehe yeah angle grinder is the best. Just dont dive into the crank threads with it. Will's got the best explanation though really Quote Link to comment Share on other sites More sharing options...
cookie456_the2nd Posted July 3, 2005 Author Report Share Posted July 3, 2005 bump, (edited - another problem!) Quote Link to comment Share on other sites More sharing options...
Siders77 Posted July 3, 2005 Report Share Posted July 3, 2005 Clamp the Freewheel Tool in a vice and then try that way? Meh, I dunno. Quote Link to comment Share on other sites More sharing options...
gilly Posted July 3, 2005 Report Share Posted July 3, 2005 (edited) I got mine off with a blowtorch, heat it up, put cold water on it to cool it, and then it should have loosened up enough to undo... Actually that might not work too well on a wheel.... :"> Edited July 3, 2005 by gilly Quote Link to comment Share on other sites More sharing options...
