Your Rear Brake Setup
Michael Hardman
Lever: Standard Magura with standard curley lever.
Calipers: Standard Magura
Hose: Monty blue + Black bridge hose
Bleed with: Water
Brake mounts: 4 bolt
Pads: Plazmatic CRM
Rim: really old onza/alex rim with a light grind
Booster: Carbonique Ultra light (and possibly ultra pointless)
what an interesting read. (Y)
Edited by RicH_87
Lever: Magura CNC.
Calipers: Magura.
Mounts: Echo 4 Bolt.
Lever Body: normal Magura, with a water bleed.
Pads: Plaz.
Hose: Normal Magura Stuff.
Rim: Old Style Echo with harsh grind.
Booster: Carbonique 4 Bolt.
(Y)
Edited by Siders77
Lever: standard black lever
Calipers: Standard Magura with monty splitter
Hose: Magura black
Bleed with: standard stuff
Brake mounts: evolution mounts
Pads: coustellier
Rim: mavic ex721 dirty as fook no grind (Y)
Booster: xtr carbon
is a water bleed beter and how do you do it? step by step please! oh and are the cnc levers any good?
Edited by scott-mad
Just bleed the brake normally, just with water instead of Oil (Y) :D
In my opinion a water bleed feels nicer. :-
EDIT: Just found this :D
1.Fill bath
2.Submerge brake
3.Undo bleed bolts
4.Attach bleed tube, but don't bother with vent tube, no need!!
5.Fill syringe with water and put on bleed tube.
6.Bleed the brake as normal, **all underwater**
7.Do it a few times to really get rid of air.
8.Remove bleed tube and do back up bleed bolts. (Underwater)
Edited by Siders77
Lever: Avid SD7
Calipers: Cane Creek DC2
Cable: Odyssey Brake Line Cable
Brake mounts: Vee Mounts
Pads: Heatsink White/Clear Pads - Heatsink Backing
Rim: Sun Ryhno Lite XL (smooth)
Beast \/ \/ \/ - I would love a ceramic rim for me 24"
Lever: Shimano XTR
Calipers: Avid Ultimate
Cablege: Clark's outer and inner
Brake mounts: 2 bolt
Pads: Heatsink Batch B material in Plazmatic CRV backings
Rim: Mavic EX721 ceramic
Mine is......
Lever: Standard Magura with CNC'd lever
Hose: Magura black
Bleed with: Water
Pads: One Plazmatic CRM and One Koxx Bloox (original one)
Rim: Onza Ronnie with a medium grind
Booster: none
Hose: Magura black
Bleed with: Water
Pads: brown bloxx
Rim: megamo with worn out grind
Booster: none
Is alrightish did the grind wrong so it slips backwards a fair bit, forwards though, what a beast! lol
Pete
Hose: Magura black
Bleed with: Water
Brake mounts: Gay Evo Mounts
Pads: Heatsink Konigs
Rim: BMF with very dead grind.
Booster: Tektro Vee
It doesn't work (Y) I need to grind my rim again, but since an accident with an angle grinder, I'm dead scared to go near a grinder again. It's even getting tempting to cheat with tar :- I also desperately need a frame with 4 bolt mounts as Evo mounts are officially wank.
Lever: Standard HS33 Gold Lever '04
Hose: Magura Black
Bleed with: Standard Bleed
Brake mounts: 4-Bolt
Pads: Green RimJams
Rim: Alex DX32 tarred, no grind
Booster: Carbonique Ultra-Light 2-Bolt
Lever: Silver hs33 body with RB blade
Caliper: Standard black hs33
Hose: Black magura, with monty splitter, bled with magura oil
Mounts: 4bolt
Pads: Paaa pads(a guy over here makes them)
Rim: 47mm koxx, fresh grind and tar
Booster: Shimano xtr carbon, drilled to 4bolt
Back in the old days when I had a d521 with a worn grind and no tar, evo mounts, paaa pads, my brake was excellent.
But I've never had a good brake with the koxx rim, altough I've tried lots of different pads(coust, plaz crm, brown bloxx) and the brake is set up nice and flat. I think, that maybe it's in the rim.. I have a DX32 over here waiting for my king hub, which I hope will solve the problem.
Edited by loffa
Lever:maggie
Calipers: maggie
Hose: black plastic maggie
Bleed with: water
Pads: coustellier
Rim: echo with a DEAD grind
Booster: shimano xtr drilled to 4-bolt
immense brake is that. the only problem i have it that the coust pads wobble so much because the backings are shit. so they wear at wank angles and occasionally randomly rub (Y)" . pad material is good though.
2000 magura with 4 bolt mounts and 5mm bolts (m4 thread though)
cnc'd magura lever
blue hose
monty hose splitter
bled with some alternative magura fluid....god knows what its called, its green though
heatsink clear pads
uber cheese rim with a grind
and tar on stand by
if the frame wasnt as flexy as a tiwanese contortionist then it might work a little better...
need a booster (Y)
